2006 Chevy Impala - Rear Door Won't Open. - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-03-2014, 08:55 AM   #16
Angry
Same Impala Problem
My 2010 Impala LT has the same problem! Rear driver's side passenger door does not work at all. It is still that way and I have just over 60,000 miles on the car so I find that also interesting. It is a safety concern for sure! Thanks for all the info though in this blog!
7Sassy is offline   Reply With Quote
Old 05-03-2014, 09:16 AM   #17
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,656
I'm curious as to how many have reported this to Transport Canada at the number provided. The more that do, the better chance of a lot of owners getting the problems corrected.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 05-03-2014, 01:48 PM   #18
DIYguy2000's Avatar
Rewards Points: 93
Agreed. I haven't called in yet, but will do it this week. I've been lucky that this problem hasn't come back since 2011, but you never know when it can happen.
DIYguy2000 is offline   Reply With Quote
Old 05-06-2014, 03:03 PM   #19
Angry
Next Step...
Originally Posted by DIYguy2000 View Post
Also as a follow up on my part, I contacted GM on-line with my concern. They phoned back a few days later and I spoke to them regarding the issue. There really wasn't much discussed during the phone call, but she did mention that there was no recall for this issue and that GM was not aware of it (yeah right...). She said that recalls are generated as a result of Transport Canada investigations, so she suggested that the next step would be to report the problem to Transport Canada. That way if there is a valid concern, Transport Canada will investigate the issue further and bring their findings to GM's attention, which could then generate a recall.
I'm not saying this will get as far as a recall, but that GM will only issue a recall if initiated by Transport Canada.
So, next step is to report it to Transport Canada if you want it to go anywhere.
Glad you're able to get some help from the dealership, but it would likely be best to bring this to Transport Canada's attention also as they probably have much more say in the matter of recalls.
Best of luck everyone! I'll be calling Transport Canada in the near future.
Alright. I've been to the dealership and spoke with GM Canada Customer Service. The Dealership confirmed it is the "rear door lock actuator" on both left and right rear doors.
They charged me 1/2 labour to determine this ($54.81). The service advisor at the dealership said GM was not going to pay to have it fixed because it is regular wear and tear and my car has 250,000 KMS on it.
I thought that was kind of funny because I don't use my back doors (don't have small children) and I don't think the KMS should effect a door lock actuator, but what do I know.
She provided me with a quote to have the work done at the dealership...
Left Side actuator $265.18
Labour $97.00
Left side total $362.18 + HST.
Right Side actuator $301.40
Labour $97.00
Right side Total $407.40 + HST.
So a total of $769.58 + HST to have them fixed (WOW)!
I have not personally heard back from GM Canada yet, but regardless I am going to follow up with Transport Canada first thing in the morning.
Just a question to everyone following this feed...
Is there anyone who is having this problem with a newer model Impala or one with much less than 250,000 KMS? I just want to see if it is wear and tear causing this or if GM just has crappy parts.
Thanks,
John.
J.Matthews is offline   Reply With Quote
Old 05-06-2014, 03:06 PM   #20
Transport Canada by calling (800)-333-0510
Labour $97.00
Labour $97.00
Thanks,
John.
Sorry I should provide that number again to make it easy for anyone who may want to help get some attention to this matter before there is an accident and someone cannot get out of the back seat because the door actuator has failed.
Old 05-06-2014, 04:58 PM   #21
123pugsy's Avatar
Thanks,
John.
Everyone knows the answer to this question and I believe you do as well.
Old 05-06-2014, 05:08 PM   #22
DIYguy2000's Avatar
Rewards Points: 93
I first experienced this problem on my 2006 impala in 2009. I purchased it with about 20,000km on it. I believe it was a return rental so I can't speak for how much use/abuse the rear doors got during that time. After I bought it, the rear doors weren't used all that much. I was probably around 80,000km in 2009 when it first happened.
Old 05-06-2014, 05:45 PM   #23
Rewards Points: 254
It's not that uncommon in a lot of models of cars. They wear out or corrode especially if they are rarely used road salt and debri gets in there and they seize up with lack of use. I replace plenty on fords too.
cjm94 is offline   Reply With Quote
Old 05-06-2014, 06:39 PM   #24
Very Insightful.
Thank you for your wealth of wisdom 123Pugsy. I first experienced the problem when the car was about 4 years old with much less KMS on it.
My point was it is a poor excuse for a bad part. I guess I should have simplified the comment.
Have a wonderful day.
JM.
Old 07-23-2014, 02:51 AM   #25
Called Transport Canada.
Just as an update for those of you who may want to follow up. I have called Transport Canada at the number I provided earlier in the blog and filed a report. The guy on the phone was helpful, but did say that it will be reviewed and depending on the seriousness of the issue and the amount of complaints they have received it may or may not be recalled.
He also told me that even if it does get recalled it will most likely take about a year or so.
Thanks to everyone for your input.
JM
Old 07-28-2014, 10:37 PM   #26
Impala rear door
We had this happen on my husbands 2006 impala recently. I called GM today and they were not aware of any issues or complaints. I filed the complaint. If you have not called and filed please do so, so they can hopefully do a recall and fix the problem. 800-222-1020 is the number make sure you have your vin number. From most of my research the driver rear is the one it's typically happens to. Haven't attempted to fix it seems like it'll be a pain in the butt.
Cport21 is offline   Reply With Quote
Old 08-15-2016, 10:42 AM   #27
Rewards Points: 2
Re: 2006 Chevy Impala - Rear Door Won't Open.
I see that I am not the only one with this problem. My problem happened recently ( the only time I had child in the back seat. Door at first would not latch but after trying the child proof lock it did. Now door will not open at all.
Contacted GM and Ministry of Transport. Have the same problem with my 2002 Olds Intrigue. Same door. With the Olds I can still open it but will not lock with the fob. Must be a GM defect.
bemeup is offline   Reply With Quote
Old 10-11-2016, 12:25 PM   #28
Rewards Points: 4
Angry
DO NOT call Transport Canada concerning any issues with rear doors seizing up in a locked position. They view it as an INCONVENIENCE (you've time to fix it), rather than a SAFETY ISSUE (unless it happens during an accident). Gee thanks, TC.
2006 Chev Impala LTZ - my husband will try to free up the locking mechanism, before taking it to the garage. There's a You Tube video concerning oiling the mechanisms & banging the lock free.
With both rear doors seized, it'll be a challenge to get the back seats out, to take the door trim panels off.
NormaJean is offline   Reply With Quote
Old 10-11-2016, 12:47 PM   #29
Rewards Points: 4
P.S. Don't bother reporting to GM Canada Customer Service (1-800-263-3777). Their GM dealers have to diagnose the problem. There is no recall, nor will one be forthcoming. Try fixing it yourself or go to your favourite mechanic.
2006 Chevy Impala - Slooooow to heat up. DIYguy2000 Automotive Repairs 15 01-23-2012 04:46 PM
chevy cavalier rear defrost doesn't work! cncccc Automotive Repairs 2 01-07-2010 01:59 PM
