2005 Volvo Xc90 T6 - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-15-2014, 12:15 AM   #16
Rewards Points: 117
Window wash,
What do mean by that??
Looked at the cv joints, them seem to be fine.
mustang64 is offline   Reply With Quote
Old 03-15-2014, 12:39 PM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
The CV Joints (half shafts) are part of the driveline.
If you have the car on a lift, crank the wheel hard to either side and rotate the wheels. If the clicking comes out of the joints, they are shot.
Is the clicking rhythmic? If not and it is just intermittent when you accelerate from a stop, check the ball joints and other suspension components.
Old 03-15-2014, 12:53 PM   #18
Rewards Points: 117
I will try that.
Tx.
Old 03-26-2014, 07:06 PM   #19
Rewards Points: 117
Hi there,
Checked out the car and it's not the cv joints and the suspension.
The noise is coming from the drive shaft just beyond the transmission.
Is there possibly a bearing of some some that is damaged and creating this noise??
Old 03-27-2014, 10:41 AM   #20
Didn't you say the car was front wheel drive or is it all wheel drive?
Old 03-28-2014, 09:53 PM   #21
Rewards Points: 117
The car is all wheel drive.
Old 03-29-2014, 01:03 PM   #22
There are serviceable bearing in the U-Joint.
Old 03-30-2014, 09:46 AM   #23
Rewards Points: 117
So there are serviceable bearings in the u joint part of the drive shaft??
Just want to make sure I understand.
Tx.
Old 03-30-2014, 05:36 PM   #24
Old 03-31-2014, 03:34 PM   #25
Rewards Points: 117
Thanks for the video, but this is my issue.
http://youtu.be/Ux9T28mWRAE
What's your recommendation on how to fix this??
Old 03-31-2014, 03:53 PM   #26
Ouch.
New transfer case/transmission output.
Old 03-31-2014, 04:18 PM   #27
Rewards Points: 117
Expensive??
Easy to fix??
Old 04-01-2014, 06:06 AM   #28
I don't know that system very well but there may be some sort of bearing in that tail shaft but with that much play, something has been ate up.
Expensive...yes. I would start looking to source the parts locally.
If you get the parts, the replacement of them should be straightforward enough.
Old 04-03-2014, 04:22 PM   #29
Rewards Points: 117
Thanks for the info. WW
There isn't that much play on my car but noise coming from that general area.
Does that mean the same problem just not as bad yet??
Old 04-06-2014, 10:32 AM   #30
Possibly.
I thought that was your video.
Either way, you need to get it fixed or replaced soon. I don't know that output situation and if it is even serviceable but most people just replace with a new unit altogether.
2005 Volvo xc 90 T6 mustang64 Automotive Repairs 7 02-20-2014 05:05 AM
2005 Volvo xc90 T6 mustang64 Automotive Repairs 7 02-13-2014 09:46 PM
2005 volvo xc 90 t6 mustang64 Automotive Repairs 8 04-21-2013 05:16 PM
Amana 2005 condensor paired with 3.5 ton Goodman unit, but I paid for a 4 ton Amana KasB HVAC 4 04-23-2011 03:41 AM
Code question regarding AFCI combination types and the 2005 NEC MattOverMinder Electrical 2 12-14-2007 03:10 PM
