2005 Volvo Xc90 T6 - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-09-2014, 11:38 AM   #1
Rewards Points: 117
2005 Volvo xc90 t6
Hear a ticking noise coming from the front of the car when I accelerate.
Looked under the car while flat on my back.
Does this car have a u-joint in the front drive shaft or does the complete drive have to be replaced??
Tx.
mustang64 is offline   Reply With Quote
Old 03-09-2014, 09:31 PM   #2
Rewards Points: 254
They have a constant velocity joint. Can be rebuilt but usually cheaper just to replace if you use an aftermarket shaft.
cjm94 is offline   Reply With Quote
Old 03-09-2014, 11:38 PM   #3
ukrkoz's Avatar
Rewards Points: 932
A rock stuck in-between the tire treads? THAT will do hell of ticking noise at acceleration....
ukrkoz is offline   Reply With Quote
Old 03-10-2014, 10:20 AM   #4
Rewards Points: 117
I believe the cv joint(boot) is just behind the wheel bearing..I'm referring to the transaxle(drive shaft).
Tx.
Old 03-10-2014, 10:26 AM   #5
Rewards Points: 254
Originally Posted by mustang64
I believe the cv joint(boot) is just behind the wheel bearing..I'm referring to the transaxle(drive shaft). Tx.
. There are two one at the bearing and one at the trans.
Old 03-10-2014, 10:40 AM   #6
Rewards Points: 117
I looked under the car and it appears that there is no u joint like I've seen in other vehicles with their transaxles or driveshafts however we want to call them.
So this is why my first question (post).
Tx.
Old 03-10-2014, 03:21 PM   #7
Rewards Points: 254
They are inside the black boots bathed in grease. Normally do not go bad unless boot tears and grease leaks out.
Old 03-10-2014, 07:05 PM   #8
Rewards Points: 79
You mean "until the boot tears and grease leaks out."
eclark is offline   Reply With Quote
Old 03-10-2014, 07:24 PM   #9
Rewards Points: 254
. True, but they are getting a lot better.
Old 03-11-2014, 10:12 AM   #10
Rewards Points: 117
Ok so you guys are talking about the front axle.
I'm talking about the front and rear drive shafts from transmission or transfer case. They appears to be no yoke and universal joints.
Old 03-11-2014, 11:05 AM   #11
Rewards Points: 254
Yea we are but some of those are built the same way. And don't have the traditional joint
Old 03-11-2014, 12:48 PM   #12
Rewards Points: 117
So am I to understand that there no u joints when it comes to the drive shafts??
But there are when it comes to the front axles??
Old 03-11-2014, 01:51 PM   #13
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
CV joint is a more complex joint and allows for a smoother articulation as compared to a U-Joint.
This is what it looks like on the outboard side:
Common part representation:
Motion Gif:
Failure looks like this (usually do to grease loss but they can fail on their own):
More commonly on trucks and older vehicles (U-joint):
The Following User Says Thank You to Windows on Wash For This Useful Post:
cjm94 (03-11-2014)
Old 03-11-2014, 09:13 PM   #14
Rewards Points: 117
Thanks for the pictures.
I believe it's not a cv joint issue.
I feel that is a drive shaft/trans axle issue.
Old 03-12-2014, 07:36 AM   #15
Rewards Points: 880
CV joints are part of the driveline.
Quick inspection on a lift should tell you whats doing.
2005 Volvo xc 90 T6 mustang64 Automotive Repairs 7 02-20-2014 06:05 AM
2005 Volvo xc90 T6 mustang64 Automotive Repairs 7 02-13-2014 10:46 PM
2005 volvo xc 90 t6 mustang64 Automotive Repairs 8 04-21-2013 06:16 PM
Amana 2005 condensor paired with 3.5 ton Goodman unit, but I paid for a 4 ton Amana KasB HVAC 4 04-23-2011 04:41 AM
Code question regarding AFCI combination types and the 2005 NEC MattOverMinder Electrical 2 12-14-2007 04:10 PM
