2005 Volvo Xc 90 T6 - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-17-2014, 07:43 PM   #1
Rewards Points: 119
2005 Volvo xc 90 T6
I recently scanned a code on the car and it showed P0300. Misfire emission level from at least 1 cylinder with three-way catalyst damage from at least 1 cylinder.
I changed the spark plugs with OEM plugs. I do not wish to change all 6 coils unless necessary.
What does this code mean and what is possibly wrong with my car??
mustang64 is offline   Reply With Quote
Old 02-17-2014, 08:55 PM   #2
Rewards Points: 254
Po300 is a random misfire at start up. Could be just worn plugs. Could be fuel bleeding down and low at initial start up... Many things with new plugs clear codes and see if it acts up again
cjm94 is offline   Reply With Quote
Old 02-17-2014, 10:57 PM   #3
Rewards Points: 119
Have cleared code. It acted up again and code came back.
What next??
Old 02-17-2014, 10:59 PM   #4
P0300 is a random miss fire fault code. That can be caused by a lot things, do you have access to the scanner?
Mbjason is offline   Reply With Quote
Old 02-17-2014, 11:01 PM   #5
When you say acted up what do you mean?
Old 02-18-2014, 01:25 AM   #6
Rewards Points: 254
A random misfire means the misfire is not lasting long enough to pinpoint which cyl. Meaning it could be just one cyl or multiple cyls. You are going to need a higher end scan tool that can monitor live misfire data and fuel trim data to find this problem. Not a real DIY diagnosis without knowing how to interpret the data it can lead to a lot of parts getting guessed at. Most higher end shops should be able to find the problem within an hours diag time. If it is real intermittent though it could take longer. If it's not acting up sensors will read correctly, but a good tech can interpret learned fuel trim values to lead them closer to the problem area.
Old 02-18-2014, 04:50 AM   #7
Rewards Points: 119
Ok.
Thank you for the information.
Old 02-20-2014, 05:05 AM   #8
Rewards Points: 119
Changed coil on cylinder #5 and cleared the code.
Car is running fine.
Thanks again to all.
The Following 2 Users Say Thank You to mustang64 For This Useful Post:
cjm94 (02-20-2014), Windows on Wash (02-20-2014)
2005 Volvo xc90 T6 mustang64 Automotive Repairs 7 02-13-2014 09:46 PM
2005 volvo xc 90 t6 mustang64 Automotive Repairs 8 04-21-2013 05:16 PM
Amana 2005 condensor paired with 3.5 ton Goodman unit, but I paid for a 4 ton Amana KasB HVAC 4 04-23-2011 03:41 AM
2005 Malibu right rear blinker? 4just1don Automotive Repairs 6 03-23-2010 09:07 PM
Code question regarding AFCI combination types and the 2005 NEC MattOverMinder Electrical 2 12-14-2007 03:10 PM
