2005 Volvo Xc 90 T6 - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-19-2013, 11:07 PM   #1
Rewards Points: 117
2005 volvo xc 90 t6
Clunking (like a water hammering sound) sound when turning the steering right/left at low speeds.
Does it have to do with front end parts or is it a power steering issue??
Thanks.
mustang64 is offline   Reply With Quote
Old 04-19-2013, 11:09 PM   #2
Rewards Points: 117
Thanks.
Can someone please help.
Old 04-20-2013, 07:34 AM   #3
Rewards Points: 1,300
Jack up the front end and check for loose suspension and steering components. Could be several different things. Bad struts, bad upper bearing plates, loose ball joints, loose tierod ends. Weak struts, Briken springs Etc Etc
danpik is offline   Reply With Quote
Old 04-20-2013, 09:53 AM   #4
Rewards Points: 14,026
Front wheeled drive? Could also be the CV joint.
http://freeasestudyguides.com/cv-joi...se-repair.html
Old 04-20-2013, 04:40 PM   #5
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
Check your cv boots for tears, if so replace the whole cv axle.
I've also seen where the rubber seat that the springs sit in wear out, and the spring can move around in the strut housing.
Most tire shops will check that sort of thing for free.
I hate signatures.
Mort is offline   Reply With Quote
Old 04-20-2013, 07:02 PM   #6
Rewards Points: 117
Had my wife crank the steering right to left and left to right, the hoses leading to the steering pump vibrate/jump/move when the clunk noise is made.Could it be a pressure issue with the power steering pump??
Old 04-20-2013, 07:16 PM   #7
ukrkoz's Avatar
Rewards Points: 978
Well, it's high pressure fluid inside, so that may be a normal vibration. Also, system simply may need to be burped. As in - you may have air inside, causing cavitation and vibration. Google power steering bleeding procedure.
Otherwise, if it's a thump-thump-thump with jerk type of thing during sharp turns, it is very likely CV joint. 1st sign is torn boots, like it was already mentioned, thank you.
ukrkoz is offline   Reply With Quote
Old 04-21-2013, 09:52 AM   #8
Rewards Points: 117
Thank you for the help from everyone.Went on line to research "bleed power steering system". There is always mention of a grinding or humming noise, my system is not making those noises just a clunk noise. Would my system still possibly need bleeding??
Thank you.
Old 04-21-2013, 05:16 PM   #9
ukrkoz's Avatar
Rewards Points: 978
Thank you.
Yes if you were 100% positive it's coming from PS. Also, Seafoam has very fine product for PS conditioning. Or you can use their Transtune product. Lucas also works well.
Won't hurt to burp your PS anyway. It's basic simple procedure.
2005 KIA Timing belts BigJim Automotive Repairs 22 05-16-2012 08:37 AM
Amana 2005 condensor paired with 3.5 ton Goodman unit, but I paid for a 4 ton Amana KasB HVAC 4 04-23-2011 03:41 AM
Brake job 2005 Dodge Ram 4x4 1500 Grizzley Automotive Repairs 1 10-28-2010 04:47 PM
2005 Ford Explorer Mystery Bell panhandlion Automotive Repairs 6 03-19-2008 09:27 PM
Code question regarding AFCI combination types and the 2005 NEC MattOverMinder Electrical 2 12-14-2007 03:10 PM
