2005 Malibu Right Rear Blinker? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-22-2010, 07:42 PM   #1
Rewards Points: 562
2005 Malibu right rear blinker?
Is there a weak spot in connections on a 2005 Malibu? My sons car I am trying to help fix for him. We played with this once before and it started working again,,however not sure what we moved or wiggled to get it to. We was woking inside the trunk,,thats all I can remember. its sorta cold to be outside working on it now,but in a month or so we will!!! Is there a place we can dialectic grease that would give better connections??
4just1don is offline   Reply With Quote
Old 02-23-2010, 12:03 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 600
Ayuh,... Probably a corroded ground wire,...
Old 02-23-2010, 02:24 PM   #3
Oldguy
Rehabber's Avatar
You will prolly need to replace the "connector plate" about $45.00 from dealer or check AZ for availability. VERY common problem with newer GMs.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 02-24-2010, 10:03 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Try here. http://car-part.com/
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-26-2010, 01:11 PM   #5
Household Handyman
Rewards Points: 1,408
"You will probably need to replace the "connector plate" about $45.00 from dealer or check AZ for availability. VERY common problem with newer GMs"
This is true. And YES, a dielectric grease is available at most parts stores. But-the "connector plate" is the likely problem. We sell many of these. Some connector plates fit many models. David
Old 03-23-2010, 11:26 AM   #6
check all the grounds first, then the intermediate connections
miles11we is offline   Reply With Quote
Old 03-23-2010, 10:07 PM   #7
Rewards Points: 562
fixed it
felt real stupid but bet others have same problem.
bulb fits in socket same both ways. one way it slips in and slips out.
other way it sort of 'clicks' in place and doesnt rattle out down the road,like the other way.
Somebody before me replaced it and got it backwards i spect.
Didnt know it COULD fit both ways and only stay in one way. thanks for the replies and hope this helps others.
best way to wire rear surround sound speakers brewmastr Electrical 5 01-10-2010 07:37 AM
Code question regarding AFCI combination types and the 2005 NEC MattOverMinder Electrical 2 12-14-2007 04:10 PM
Rear Window Seal Crista Automotive Repairs 2 11-18-2007 11:16 AM
1994 camry rear suspension/tires problem marks5894 Automotive Repairs 2 11-05-2007 06:12 PM
rear entryway/stairwell LanterDan Remodeling 1 11-02-2006 12:32 PM
