2005 Jeep Grand Cherokee Starting Issue - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-06-2014, 12:14 PM   #1
I have a 2005 Jeep Grand Cherokee Limited 8 cylinder 5.7 Hemi vehicle.
Over the last few months we have replaced the battery, starter and just had the alternator checked and it is good. Every morning it has to be jump started.
Yesterday out of the blue we were at a stop light and the vehicle stalled it did start right back up but when we got to our destination we were in there for about half an hour it wouldn't start back up it had to be jump started.
Any suggestions on what this could be or what to look for?
lovebug is offline   Reply With Quote
Old 04-06-2014, 12:44 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,592
You need to have a qualified technician look at the electrical system.
If it is dying overnight, you have some sort of open circuit that is draining the battery (assuming the batter and alternator are good and were replaced with working units (they can and do fail even after replacement)).
How was the alternator tested?
The Following User Says Thank You to Windows on Wash For This Useful Post:
lovebug (04-06-2014)
Old 04-06-2014, 01:37 PM   #3
The alternator was tested by Advanced Auto Parts 3 times and came back as being good each time. We just had the battery tested and was advised it passed as well even though it was reading a bit low (could have to do with the fact that we had to jump start it to get to the store and only drove it for about 10-15mins to get there) All other tests they did as well came back as passed as well.
Old 04-06-2014, 03:01 PM   #4
Could an open circuit be caused by a fuse not being pushed all the way in?
Old 04-06-2014, 04:23 PM   #5
ukrkoz's Avatar
Rewards Points: 992
1. You have parasitic drain. Google how to spot it.
2. Your alternator belt is loose, ergo, battery is not charged. Check charging voltage with engine running. If it's below 13V, it's not gonna do much good.
3. you have bad ground somewhere or battery cables are oxydized and need to be cleaned.
4. All of the above. Happens.
ukrkoz is offline   Reply With Quote
The Following 2 Users Say Thank You to ukrkoz For This Useful Post:
lovebug (04-06-2014), Windows on Wash (04-07-2014)
Old 04-06-2014, 04:25 PM   #6
ukrkoz's Avatar
Rewards Points: 992
Btw, that your car stalls at red light, tells me that your alternator is not providing enough juice. You can, with good alternator, engine running, take cables off battery, and it all should run just fine. Maybe a dirty or "getting there" connector on alternator?
The Following User Says Thank You to ukrkoz For This Useful Post:
Old 04-06-2014, 04:38 PM   #7
Rewards Points: 392
An alternator that's charging can still drain the battery if there's a defective diode.
rustyjames is offline   Reply With Quote
The Following User Says Thank You to rustyjames For This Useful Post:
Old 04-06-2014, 04:57 PM   #8
So does this mean that even my alternator is testing good it could still be bad? We have cleaned it up and put it back in but still have the same problem.
Old 04-06-2014, 07:22 PM   #9
I don't know much about vehicles, but those symptoms sound similar to my daughter's 2001 Grand Cherokee.
I may be way off, but you never know
Someone suggested she had a tank of crappy fuel. We dumped a bottles of fuel cleaner into the tank and the problem vanished.
Now she makes sure she doesn't go to discount gas stations.
creeper is offline   Reply With Quote
The Following User Says Thank You to creeper For This Useful Post:
lovebug (04-07-2014)
Old 04-06-2014, 09:00 PM   #10
ukrkoz's Avatar
Rewards Points: 992
No, that means few things:
1. alternator test was not done right
2. alternator test was done right but between alternator and battery you have lost power
3. you have good power from alternator but it does not get to the battery itself
4. it gets to the battery but something drains the battery fast and furious.
I'd strongly recommend to start with VERY basic cause #1: dirty terminals and poles and bad ground.
Otherwise, unless you the type, get it to a knowledgeable car electrician. MANY things can go wrong in case like this and everyone's guess is as good as others'.
lovebug (04-07-2014), Windows on Wash (04-09-2014)
Old 04-08-2014, 08:26 AM   #11
Just wanted to say Thank You to everyone who made a suggestion about my vehicle. We have taken it to a mechanic...where they have specialist in auto electrical systems as well as jeep specialists so they should get it figured out. Not looking forward to the bill though....lol.
Old 04-09-2014, 07:04 AM   #12
Might not be as bad as you think.
Unfortunately, AutoZone and Advance Auto Parts are not the bastions of great technicians so it is not unlikely they missed the diagnosis on the alternator.
2004 Jeep Grand Cherokee starting problems jjohns29 Automotive Repairs 18 11-18-2012 09:24 AM
2004 Jeep Cherokee Starting Issue tpvahey General DIY Discussions 5 12-05-2011 04:48 PM
Starting Issue w/Miller Heat Pump bgbrown125 HVAC 11 08-17-2011 07:38 AM
lawn tractor starting issue lyonheart Landscaping & Lawn Care 3 05-23-2009 11:54 AM
Jeep Fuel Delivery Issues ocoee Automotive Repairs 5 01-15-2009 05:02 PM
