2005 Honda Accord Smelly Sock Smell - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-20-2012, 03:30 AM   #1
Rewards Points: 83
2005 Honda Accord smelly sock smell
How can I remedy that stinky smelly sock odor from my AC?
hawaiiboy is offline   Reply With Quote
Old 01-20-2012, 04:15 AM   #2
Busy DIYer
picflight's Avatar
Rewards Points: 150
Dry it out, the carpet and padding underneath are wet. Probably due to condensation leaking in the passenger foot area.
picflight is offline   Reply With Quote
Old 01-20-2012, 05:53 AM   #3
Roy Howard
47howard's Avatar
get it professionally cleaned and shampooed. then add air fresheners and let it dry properly. it is probably a small leakage
47howard is offline   Reply With Quote
Old 01-20-2012, 08:07 AM   #4
Learning Things Every Day
Jay 78's Avatar
Personally, I wouldn't use/suggest air fresheners, as they only mask smells. I use this:
It penetrates the fabric to remove odors, not just cover them up. It's great stuff, and should be found at any auto parts store.
Under Construction
Jay 78 is offline   Reply With Quote
Old 01-20-2012, 09:10 AM   #5
Rewards Points: 336
I had that problem with my mini van. The smell was only there when I ran the a/c. There was a filter that had to be replaced. If I remember right, it was called the 'cabin air filter'. After it was replaced, the smelly sock odor went away.
gma2rjc is online now   Reply With Quote
Old 01-20-2012, 11:24 AM   #6
Rewards Points: 83
Don't think I have a wetted carpet:subfloor. I also had changed the cabin air filter without success ;-(.
Old 01-20-2012, 01:34 PM   #7
Rewards Points: 254
The a/c evaporator core can get mold on it and cause the smell. They make a spay to satiate and kill the bacteria causing the smell. Not sure of the name ford makes some. Check with your parts store our ford dealer if they can't help you.
cjm94 is offline   Reply With Quote
Old 01-20-2012, 02:29 PM   #8
Rewards Points: 252
While running the fan/ac, spray some Lysol in the vent at the bottom of the windshield (on the outside)
shazapple is offline   Reply With Quote
Old 01-20-2012, 02:35 PM   #9
The A/C core causes water to condense like the water on the outside of a glass of a cold drink.
That water drains out a tube below that A/C core. This tube can be seen coming out on the passenger side of the lower firewall in the engine compartment typically.
That tube can get clogged, water then pools in the A/C core area. Then stinks! The A/C will come on in the winter for defrost.
Use a wire hanger to unclog that tube.
They spray "spray disinfectant" into the intake vent for the A/C system with the fan on. And spray whole car. Let the air circulate a while, then sit.
Billy_Bob is offline   Reply With Quote
Old 01-20-2012, 06:09 PM   #10
raylo32's Avatar
Rewards Points: 1,238
This sounds like a Seinfeld episode....
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
picflight (01-21-2012)
Old 01-21-2012, 08:39 PM   #11
ukrkoz's Avatar
Rewards Points: 934
ok, reason you have MUSKY smell coming out when a/c runs is because you have mold build up on radiator. wait until black chunks will start flying out of vents!
reason you have mold build up is because you, like most, do not shut down a/c right. you simply turn it off, or turn engine off, or turn fan off.
BAD IDEA. as a result, on very cold exchange radiator, there's accumulation of condensate. slowly but steadily, it starts creating wet, damp nursery for mold to grow.
right way of turning a/c off is to plan ahead. you know you'll park/shut down, in next few minutes. wisely, you turn a/c off, BUT KEEP FAN RUNNING. what it does, it dries out radiator.
OK, so what do we do now? Ideally, remove exchange radiator and clean it. less ideally, set a/c to highest possible air flow, and start spraying, from outside, some known strong disinfectant/mold killer, into intake vents. I used Lysol products. WhatOdor works well, but it will not kill mold, just smell. you need to kill mold, or smell will come back. Will take you several squirt bottles to do the job. do not even try spray cans, you'll go through them in a heartbeat and accomplish nothing.
ukrkoz is online now   Reply With Quote
Old 01-21-2012, 09:05 PM   #12
Is called the evaparator. The evaparator has mold on it. Run the heat before you turn the veh off.
There is a cleaner, you drill a small hole in the evaparator box and inject the cleaner. Be carefull not to hit the evaparator.
Hardway is offline   Reply With Quote
Old 01-22-2012, 04:54 PM   #13
ukrkoz's Avatar
Rewards Points: 934
thank you for clarification.
Old 01-23-2012, 06:26 AM   #14
Rewards Points: 274
This worked on a vehicle I once owned. Spray like crazy, and then let it sit over night. You may have to do it a few times, but it will eventually kill the mold.
polarzak is offline   Reply With Quote
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 07:42 PM
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 09:08 AM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
2010 honda accord MagicalHome Off Topic 4 04-28-2010 09:36 AM
