Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-23-2012, 07:19 PM   #1
2005 Honda Accord 4 Cylinder
Hi.
My check engine light came on yesterday. The codes are P0139 (downstream oxygen censor circuit, slow response) and P0420 (catalyst system efficiency below threshold). Here is what I am thinking about doing. I want to replace the oxygen censor and I am hoping that this will fix both of codes since the oxygen censor is connected to the cat. Also, it is WAY cheaper to start here. What do you think?
mathman32 is offline   Reply With Quote
Old 05-23-2012, 08:13 PM   #2
World's Tallest Midget
Mort's Avatar
I think you're right. How long has it been since you had a tuneup? It may be beneficial to put new plugs in it at the same time.
Mort is offline   Reply With Quote
Old 05-23-2012, 09:23 PM   #3
Those oxygen sensors are pretty common to fail, start there and see what happens
D-rock is offline   Reply With Quote
Old 05-23-2012, 10:48 PM   #4
It was a dark and stormy
Yoyizit's Avatar
Well, mathman, by the numbers, for this decision to be a toss up,
if the O2 sensor costs 1/10th (way cheaper?) of the catalytic stuff
then
the sensor should be 10x (pretty common to fail?) more likely to fail,
assuming your labor is free.
Let's price out some stuff and see what kind of odds we need for this to be a toss up. The numbers will make things more black and white.
You still may be wrong but at least you had a good reason for your choice.
Old 05-24-2012, 07:32 PM   #5
Thanks for your help people. I'm going to change the 02 censor this weekend and see what happens.
Mort - I haven't had a tune up in a while, but I think new spark plugs may be a good idea as well.
Old 05-24-2012, 08:55 PM   #6
factory plugs are designed to go around 110,000 miles
Old 05-24-2012, 09:54 PM   #7
Mort's Avatar
Yeah, and some cars can get 7500 miles between oil changes. That doesn't mean I'd do it.
Old 05-25-2012, 04:04 PM   #8
Long life spark plugs can start to get pricey, no need to spend money on something that will have no effect on anything.
Old 05-26-2012, 09:37 AM   #9
So the 02 censor has been replaced and the check engine light has disappeared (YES!!!).
Old 05-26-2012, 12:36 PM   #10
ukrkoz's Avatar
and next thing to do is to pull ECM fuse out for about 15 minutes, to clear all presets off ECM. It will learn now how to drive with new O2 sensor.
ukrkoz is offline   Reply With Quote
2005 Honda Accord smelly sock smell hawaiiboy Automotive Repairs 13 01-23-2012 06:26 AM
Chainsaw repair - cylinder damage? holmes55 Tools 3 01-01-2012 07:23 PM
Is Honda Generator worth the cost? Dave_T Electrical 2 11-22-2011 10:38 AM
2010 honda accord MagicalHome Off Topic 4 04-28-2010 09:36 AM
Cost of boiler & cylinder replacement abaminog Off Topic 9 03-31-2010 08:05 PM
