2005 Dodge Ram 1500 Brake Job - Automotive Repairs - Page 3 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-25-2012, 01:41 PM   #31
Rewards Points: 276
The two bolts that hold the caliper bracket were hard to loosen. I broke a 3/8" ratchet, a cheapo 21mm socket.
I wound up having to buy a new 21mm impact socket and a 1/2" breaker bar at my local NAPA. The guy at NAPA told me that these are usually put on with locktite and that the red locktite must be heated up to loosen. I din't have to heat mine up fortunately.
2005 Dodge Ram 1500 Brake Job-p1000395.jpg   2005 Dodge Ram 1500 Brake Job-p1000394.jpg
Jim F is offline   Reply With Quote
Old 03-25-2012, 01:46 PM   #32
Rewards Points: 276
New pads and rotors on and calipers back in place. The outer pad was completely worn out and metal to metal against the rotor. I had known for some time that they needed to be replaced. I was just waiting for a break in the weather so I could do it. I opted to just replace both rotors and usually do when I do a brake job. Along with needing to be resurfaced in a shop, the fins fill up with rust so the old rotors don't cool as efficiently.
These were easier than other brakes I have replaced. The inner and outer pads are identical and the clips stayed in place while I removed and replaced the pads. The other side went much quicker since I had all the tools gathered for the job.
2005 Dodge Ram 1500 Brake Job-p1000396.jpg   2005 Dodge Ram 1500 Brake Job-p1000397.jpg
Old 04-25-2012, 05:50 PM   #33
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
Actually, when you're compressing your pistons, crack the bleeder screw on the caliper. Then you're not forcing fluid all the way through the lines. It won't be enough to get air in the lines.
That, and silicone lube is your friend. Lube everything that is supposed to move and slide, or you'll be replacing the brakes again next year.
I hate signatures.
Mort is offline   Reply With Quote
Dodge Caravan 2005 driver door lock Wildie Automotive Repairs 11 11-20-2008 03:18 PM
trailer wireing 1500 ram 79monztah Automotive Repairs 2 05-15-2008 10:49 PM
Code question regarding AFCI combination types and the 2005 NEC MattOverMinder Electrical 2 12-14-2007 03:10 PM
2005 Dodge brake wiring schematic dwallace Automotive Repairs 2 09-10-2007 07:48 AM
