Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-07-2007, 01:57 PM   #1
2005 Dodge brake wiring schematic
Hi all, i am hooking up a brake controller to my 2005 Dodge Ram, 1500, 2 wheel drive, quad cab, 4.7. I used the generic diagram that came with the controller to find my cold/switched wire from the brake switch.According to the manual my wire should be white/tan, however, it seems that is constant power because it reads 24 volts at the trailer connector always. I know that i can put pins in each of the wires and depress the brake pedal and check the wires, but im getting old and my back hurts when im tucked under the steering wheel . Does anyone know what wire i should be using,or can someone point me to a diagram online. By the way, there are approx 6 wires in the harness.
dwallace is offline   Reply With Quote
Old 09-09-2007, 07:49 PM   #2
Extreme DIY'r Adk's, NY
If your vehicle isnt equipped with a tow package you may not have the wire back there. Plus they arent on their own isolated fuses to protect the truck from trailer wiring problems and dimming due to load and length of wires. You may have to find the wire up front and run back.
crecore is offline   Reply With Quote
Old 09-10-2007, 08:48 AM   #3
Thanks for the reply. I did have it right. My original tester must have been faulty. I hooked a 12V test light to the circuit and watched the light dim and brighten when the manual slide lever on the brake controller was used. Hooked up, and ready to roll.
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
