2004 Stratus Help Needed - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-04-2009, 11:48 AM   #1
frustrated
grumpypapa's Avatar
Question
2004 stratus help needed
im working on a 2004 dodge stratus and trying to figure out a squeeking (rubber) sound comming from the left (drivers) side of the rack. the boot seems fine clamps are on so the boot isnt slipping on the shaft. whats inside the boot that can be making the noise
grumpypapa is offline   Reply With Quote
Old 03-04-2009, 10:01 PM   #2
Rewards Points: 150
Inner tie rod end.
Gary
Gary_602z is offline   Reply With Quote
Old 03-19-2009, 04:15 AM   #3
I try to not screw up.
Agreed. Knock off the outer tierod ind and move the tierod up and down by hand to try to duplicate the squeak.
There isn't anything in the strut besides the strut itself that can make noise when going up and down. If you get a squeak when turning it could be the strut bearing.
2long4u is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Wire Needed for GF / Arc Fault breaker jamiedolan Electrical 13 09-20-2009 09:15 AM
CanLites needed in Insulation addition? i009981 Building & Construction 4 12-13-2007 10:26 PM
How much time needed aritoni Painting 1 01-12-2007 11:42 PM
