2004 S10 Blazer Gas Tank - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-18-2008, 08:27 AM   #1
2004 S10 Blazer gas tank
Over the past year I have had an intermittent problem with my gas tank. I have had the check engine light come on and sometimes the can not put gas in the tank even thou it is only 1/4 full. Last week I stopped for gas and they could only put in about 1 gallon. It kept spilling out despite me being almost on empty. I pulled out of the station and noticed the check engine light went out so I pulled into the next station and it filled up no problem. This is like the 3rd time this has happened in less then a year . Also the truck passed inspection not long before it happened first time and they did the gas tank test and it passed that.
Any thoughts???
Joe
joeyuk is offline   Reply With Quote
Old 06-03-2008, 04:23 PM   #2
are you positive the gas guage is reading correctly? Also climb under the truck and check the filler neck to see if it is kinked at all.
jvc120er is offline   Reply With Quote
Old 06-11-2008, 05:27 PM   #3
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Did you check the engine? Was it still there?
The check engine light will come on if your gas cap isn't tight. You probably have a bad float or sending unit inside the tank. I'd keep a log on your mileage and maybe carry a gas can until you figure it out or fix it.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 06-12-2008, 02:04 PM   #4
This could happen if your vent is blocked as well. If the air in the tank can't get out when you fill it, the gas will back up in the fill tube, and shut off the gas nozzle.
NateHanson is offline   Reply With Quote
Old 06-12-2008, 05:03 PM   #5
I think that is the problem. The big question is what I can do about it. I wonder why it is intermitent.
Old 06-13-2008, 09:41 AM   #6
47_47's Avatar
Rewards Points: 62
Did you have the system scanned for codes? The controller(s) that turned on the check engine light will store the data at the time of the fault(s). The BCM will control your fuel gage and the ECM should control the EVAP circuits.
Check for code(s) and get wiring diagram(s) and check for areas in common. Intermittents are usually caused by wiring connections (terminal tightness) or bad grounds.
47_47 is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 11:19 AM
Relocating Oil Tank jbboater HVAC 2 03-23-2008 07:50 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
