Hey all. I have been noticing that my trunk seems wet after a hard rain, and when I opened up my spare wheel well, it was SLOSHING with water! I was able to pull one of the rubber rings so the water drained, but my main concern is HOW the water is getting in.
I am posting some photos so that you guys can see where the trunk is always wet, and then hopefully we can extrapolate as to where the water is coming in...
Someone suggested that the rear lights may be the problem as the water drains from around the top of the trunk and empties over the lights, so I took out the rear drivers side light, and siliconed the bolts and holes around it.
I don't believe that is it though... don't know why, just a gut feeling.
I took a picture of the trunk with the carpeting pulled away, and I dont know what I am looking at, but it appears that work has been done on this trunk before!
This water leaking is a HUGE issue, because I am a computer repair guy, and I have electronics in the trunk on a regular basis and they can NOT get wet!
PS - If you need larger versions of the photos, the direct links are:
http://www.aaa-computerrepair.com/pictures/trunk1.jpg
http://www.aaa-computerrepair.com/pictures/trunk2.jpg
http://www.aaa-computerrepair.com/pictures/trunk3.jpg
