2003 Silverado Air Conditioner Recharge - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-13-2009, 04:40 PM   #1
2003 silverado air conditioner recharge
How can i tell which port is high pressure and which is low pressure
emen657 is offline   Reply With Quote
Old 06-15-2009, 01:53 PM   #2
47_47's Avatar
Rewards Points: 76
The high side port is on the discharge line and the low side port on the suction line.
47_47 is online now   Reply With Quote
Old 06-15-2009, 02:53 PM   #3
Oldguy
Rehabber's Avatar
With the switch to R134A refrigerants, the connectors are different. The charge connector (low side) will not fit the high side.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 06-16-2009, 10:44 PM   #4
The high side port is bigger.
kchopper is offline   Reply With Quote
03 silverado speedometer wetz Automotive Repairs 15 10-22-2015 11:17 AM
Novel Way to increase effeciency of portable Air conditioner Tell me what you think macmini HVAC 5 05-25-2009 05:58 AM
Home Central Air Unit has No Freon Recharge Valve nofrey HVAC 1 04-28-2009 07:40 PM
Installing window air conditioner mary60 Electrical 1 08-14-2008 06:25 PM
window unit air conditioner help? greenvorlon Appliances 1 08-03-2007 11:50 AM
