2003 S-10 Rear End - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-19-2011, 09:47 AM   #1
AGWhitehouse's Avatar
2003 S-10 Rear End
2003 Chevrolet S-10 Extended Cab LS 4.3L V-6 2WD
My driver's side rear bearing is on it's way out. Is that bearing pressed on the axle shaft? Pressed into the rear end housing? Or some alternative? If it's pressed then a shop is in my future as those tools I do not possess. If it's an alternative, I'll be taking it on myself when the time comes.
AGWhitehouse is offline   Reply With Quote
Old 07-19-2011, 05:13 PM   #2
Rewards Points: 252
I think your S10 should be similar to my K10 axles. You should be able to remove the bearing with a bearing puller/slide hammer. You have to pull the axle first, though. So, you will have to open the diff, remove the C clip and remove the axle.
Marty1Mc is offline   Reply With Quote
estimating flange height for rear outlet toilet JakAHearts Plumbing 6 07-04-2010 04:53 PM
Replacing rear oil main seal wvphysics Automotive Repairs 3 06-05-2010 01:40 AM
best way to wire rear surround sound speakers brewmastr Electrical 5 01-10-2010 06:37 AM
Rear Window Seal Crista Automotive Repairs 2 11-18-2007 10:16 AM
1994 camry rear suspension/tires problem marks5894 Automotive Repairs 2 11-05-2007 05:12 PM
