2003 Ford Focus Engine Acts Like Its Starving For Fuel - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-02-2010, 07:05 PM   #1
2003 ford focus engine acts like its starving for fuel
hi,
i have a 2003 ford focus wagon se. when driving along, sometimes the engine will die down, and then pickup, then run ok. does it quite often now. the car has 120,000 miles on it, and has never had anything replaced on the engine except for spark plugs and a thermostat housing. im thinking maybe the fuel filter needs to be changed, and if that doesnt cure it, maybe the injectors need cleaning, or maybe the fuel pump is on its way out. any ideas? i dont think its electrical/electronic, but it could be...bob
bobo60 is offline   Reply With Quote
Old 04-02-2010, 07:14 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,342
I think you nailed it with the fuel filter. That's where I would start.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-03-2010, 08:15 AM   #3
Do all the recommended maintenance listed in a Haynes service manual (auto parts store) or factory service manual set (order from helminc.com), and you will find that your vehicle runs much better!
Billy_Bob is offline   Reply With Quote
Old 04-14-2010, 11:55 AM   #4
cowboy dan's Avatar
Originally Posted by bobo60 View Post
hi,
take it to a shop that u can trust. always start with the computer. have it scanned for codes. don't bother with anything else untill u scan that computer.what you get might surprise you.
i won't mention it now cause if i tell you after you won't be mad at me
cowboy dan is offline   Reply With Quote
Old 08-05-2014, 11:14 AM   #5
I ask the impossible!
Rewards Points: 660
My 2004 SVT had similar mileage and symptoms, and I went through the things you listed but the problem remained: fuel filter, cleaned injectors, replaced fuel pump. Also replaced coil, plugs and plug wires.
The real problem, as it turned out, was with the ignition coil primary wire. (i.e. where the wire harness connects to the ignition coil).
This is apparently a common problem due to an undersized wire that develops a fatigue break. There's a Dorman replacement part with heavier gage wire that you splice into the wire harness to replace it. Check that first.
Computer codes won't tell you this problem. On-board diagnostics don't really cover all issues that actually affect a car's driveability... Case in point, 2012 Silverado stopped running. Problem was somebody put water in the gas tank. Computer indicated no problem found. When I had the Focus problem, the only code was related to the fuel pump (because I pulled the fuse to depressurize the system when changing the fuel pump.)
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Replacing water pump on ford focus. bobo60 Automotive Repairs 2 06-19-2009 08:30 AM
Check Engine light Code P0430 Ford Explorer Mr Chips Automotive Repairs 4 04-09-2008 11:02 AM
