2003 Escape Antifreeze - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-06-2013, 10:27 AM   #1
Home Remodeler
Rewards Points: 164
2003 Escape antifreeze
Need to replace the coolant in the 2003 Ford escape, V6. It has the yellow Motorcraft Premium Gold in it. Ford says not to use any other brand. The Prestone Extended says for all makes, all models, any color. Who should I believe, Ford or Prestone.
mikey48 is offline   Reply With Quote
Old 10-06-2013, 10:57 AM   #2
I don't have the details handy...but I did do the research a while back for my '04 6.0 diesel. Do use the Ford antifreeze. Considering it's for most owners it's a once every 8-10 years job, the difference in cost, amortizing over the extended time period, is pretty small
RoyalAcresRod is offline   Reply With Quote
Old 10-06-2013, 05:28 PM   #3
ukrkoz's Avatar
Rewards Points: 946
Prestone is correct. Their stuff mixes even with such a nightmare as GM Dexcool.
ukrkoz is offline   Reply With Quote
Old 10-06-2013, 05:29 PM   #4
ukrkoz's Avatar
Rewards Points: 946
Just to make sure. In this country, if it's printed on something, it's guaranteed. Prestone's lawyers won't them put such statement onto a jar, if that was not tested.
Old 10-06-2013, 05:33 PM   #5
Rewards Points: 6,652
The only way to replace it with something else, than the Motorcraft stuff, is take it into a shop that will pressurize the system, as they flush it out with a acid flush. The shop I take our vehicles to, was out of the universal coolant they use; they had to replace the Dexcool in my son's 2005 G6 with Dexcool.
I will probably take it in next Summer, before he leaves for the university he plans to attend, and have them flush out the Dexcool and replace with the universal coolant.
Problem with stuff like Dexcool and like coolants that are made out of Sugars, is that they thicken like Molasses if air is allowed to enter the system.
Old 10-06-2013, 06:51 PM   #6
Home Remodeler
Rewards Points: 164
I flushed the crap out of the system and used the prestone. Will let you know how it worked in 5 years. LOL
Old 10-06-2013, 07:57 PM   #7
If you only flushed with water, it is still going to have the old stuff in the block, and heater core. You have to use either Oxalic acid Radiator flush, or Muriatic Acid to flush everything out. CLR will also work for Cooling system flushing.
Old 10-08-2013, 05:59 PM   #8
Rewards Points: 1,062
UK, ol bud, maybe so, but Im not so easily convinced. Just because its printed, doesnt mean its truly tested scientifically. test results can be skewed easily to favor outcome. Happens all the time, and if it happenes with pharma drugs (well documented, and it does- gambling with human lives), it can happen in the stupid car market.
Cheap guarantee- it will skyrocket sales, and risk of lawsuit is so remote- plaintiff has burden of proof of damage directly caused by product. The sales is worth the risk. Dont be fooled, felow members.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 10-08-2013, 06:00 PM   #9
I would never trust coolant over 5 years.........
Old 10-08-2013, 09:38 PM   #10
Home Remodeler
Rewards Points: 164
Me either noquacks
Old 10-09-2013, 05:45 PM   #11
be safe, mickey, dont go over 5 yrs. We should be grateful- used to be 2 yrs with the older /lower tech stuff.
Old 10-09-2013, 08:39 PM   #12
Home Remodeler
Rewards Points: 164
OK. I will let you know if I have any problems prior to 4 years 11 months.
2003 Escape keeps dieing on freeway. mikey48 Automotive Repairs 6 10-06-2013 10:16 AM
Basement windows Toddr Windows and Doors 3 10-31-2012 06:14 PM
Help with my Egress Question brockmiera Building & Construction 19 10-30-2012 03:20 PM
how to go about making a window bigger in my basement so that I can put a bedroom urgurl031 Remodeling 12 10-07-2012 05:26 PM
GM Theftlock 2003 polarzak Automotive Repairs 4 03-20-2012 11:06 AM
