2002 Subaru, No Power - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-25-2009, 05:38 PM   #1
Question
2002 subaru, no power
looking for some help, my 2002 subaru could not make it up my driveway yesterday. it has been jerking and stuttering latley, it will also just drop in power at highway speed and the recover. i have changed the fuel filter an the problem is still present. the car is not throwing any codes at any time and the check engine light is not on. any help
osdhero is offline   Reply With Quote
Old 06-25-2009, 08:58 PM   #2
Learning by Doing
Leah Frances's Avatar
Go to: www.nasioc.com Very active subaru board. I'm sure they can help likety-split.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-25-2009, 10:14 PM   #3
Could be an intermittent elec. problem, like a bad solder joint.
You have a better chance of fixing it if you can reliably reproduce the fault.
This problem can't have too many candidates as a point of origin since you have no other symptoms.
Your local library might have books that mechanics study to pass their ASE exams, and these are full of good ideas as to cause and effect; the problem is the books are not arranged to be used in this manner.
Also, dealers have a data recording device which they deny having, that they hook up and then when the fault occurs as you are driving around you press a button and the device stores what the car's computer was thinking just before the fault.
It's a specialized version of one of these.
http://www.dataq.com/c_cr/?source=go...FeFM5QodCUasBw
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 06:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
