2002 Saturn Vue Oil In The Coolant - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-27-2009, 01:06 PM   #1
2002 Saturn Vue Oil in the Coolant
In our 2002 Saturn Vue, which we recently purchased, there's oil in the coolant. When the coolant tank's PSI increased too much, excess oily coolant ran out through the pressure relief hose and on to various parts underneath. Can anyone shed some light on the possible causes of this?
The vehicle has about 115,000 miles and is an automatic.
thanks for any help.
brokenhammer is offline   Reply With Quote
Old 06-27-2009, 03:40 PM   #2
Possibly a head gasket issue
kchopper is offline   Reply With Quote
Old 06-28-2009, 06:38 PM   #3
Household Handyman
Rewards Points: 1,408
Are you sure this is oil or transmission fluid? Go to any local radiator shop and ask them that question and I'll bet you they will tell you the transmission cooler is notorious for leaking on these units. I work for a friends auto parts store and we sell quite a few of these radiators. They are not worth taking apart to try and fix, just replace them in our "throw away society". It could be a head gasket, but eliminate all possibilities before spending any monies. Good Luck, David
Old 06-29-2009, 12:24 PM   #4
47_47's Avatar
Rewards Points: 62
The oil must be pressurized (~20 psig) to get into the coolant. Do not drive this car. Coolant in the oil will ruin bearings and soften and destroy all rubber components (hoses, tstat, water pump...). The 3.0l had problems with the engine oil cooler leaking coolant externally. I'd also check for TSB's.
Another note, S Series (1.9l) had problems with cracked cam journals and got oil in the coolant. It looked like a slimy chocolate milk shake.
47_47 is offline   Reply With Quote
My saturn shakes really bad while idling?? timthetoolman Automotive Repairs 14 12-04-2009 09:38 PM
2002 Pontiac Grand Prix c.sherry Automotive Repairs 1 06-13-2009 07:15 PM
Coolant lasts just 3 years?? York. windowguy HVAC 14 05-03-2009 11:11 AM
help, Poor performing AC, coolant leak? damaged coil? images maverick06 HVAC 5 07-31-2007 05:30 PM
