2002 Pontiac Grand Prix Electrical Problem - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-20-2008, 05:04 PM   #1
I have a 2002 Pontiac Grand Prix (about 70,000 miles). For the last year or so the car has what appears to be electrical problems. About 10% of the time at start up, the fan for AC/heat does not work and the automatic lights do not go on (both at the same time). After about 20 minutes they both kick on. (FYI, I am able to manually turn on the lights at any time.) Numerous mechanics cannot figure this out.
Anyone ever have this problem with Pontiacs? Any possible solutions?
Thanks for any feedback.
bipper is offline   Reply With Quote
Old 04-21-2008, 10:24 AM   #2
47_47's Avatar
Rewards Points: 58
Unfortunately I do not have experience with Pontiacs, but a few things to check.
Was this car ever involved in an accident? You may have a wire pinched/chaffed and corroded.
Has the BCM been scanned for DTC's?
Intermittents are the hardest to find. I suspect either a bad wire, terminal tightness or BCM, but you need to take this to a qualified tech.
47_47 is offline   Reply With Quote
Old 04-23-2008, 07:44 AM   #3
Hey,
Yes, the car was in an accident (I was given the car on the cheap and I have noticed evidence of a previous incident).
Thanks for the reply. I will instruct my next mechanic to check the things you have recommended.
Old 04-23-2008, 05:59 PM   #4
Learning by Doing
Leah Frances's Avatar
Check pertinent relays. My volvo's brights would only work if you turned the left turn blinker on first. I found a scorched relay under the dash - trip to the pick and pull: $2.00; working brights: priceless.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-02-2009, 04:55 PM   #5
I'm not sure if this post will be out of date.
The problem I've had was that I would get high speed only and
when I would try to lower the speed then the AC would quit. I
believe I did find the problem.Locate the HAVC fuse inside the glove box.
(you're goning to need a volt meter for this)When the AC is working check the voltage at the fuse.It should be 12 volts.Next try operating the AC system.(it probably would be better with 2 people for this)If the system
fails ,check the voltage again.It may have dropped to either 2 or 4 volts.
This is because a wire coming from the IGNITION SWITCH that supplies the fuse label HVAC loses voltage because of a problem in the IGNITION SWITCH.The color of the wire is orange.It would be a good idea to do the same test I descibed above to check the orange wire at the ignition switch.
HDVROD is offline   Reply With Quote
Old 07-06-2009, 11:06 AM   #6
Thumbs up
HDVROD,
Thanks, my mechanic fixed the problem by doing just that - changing the ignition switch. I am not sure if did this diagnostic procedure. But I hope that it's not just a temporary solution...until it stops working again. It's been a while so I think it's 'cured.'
Self induced electrical problem :( domiflichi General DIY Discussions 7 07-10-2008 08:33 AM
Major electrical problem!? Rexkwondo Electrical 7 02-06-2008 04:13 PM
Mystery Electrical Problem sippin Electrical 14 11-07-2007 10:42 AM
electrical outlet problem ? BEN17 Electrical 1 07-29-2007 06:23 PM
Perplexing electrical problem prglor Electrical 4 05-30-2007 02:20 PM
