2002 Pontiac Gp - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-11-2009, 08:14 PM   #1
Question
2002 pontiac gp
i cant get my ignition switch to go to off position any ideas?,
black3333 is offline   Reply With Quote
Old 10-11-2009, 08:44 PM   #2
Apprentice
UpComingBuilder's Avatar
I think If your talking about ur key not going all the way back to get ur key out the same thing happened to my 2001 grand prix.
My mechanic took the cap off under the steering wheel, so when I take my key out I have to press a button.
>>SooN<<
UpComingBuilder is offline   Reply With Quote
Old 10-11-2009, 10:57 PM   #3
SELLC's Avatar
If your key wont come out of the ignition it can be one of a few diffrent things. Depending on if its a manual transmission will dictate if there is a button to remove it (usually located near the ignition where the key goes).
Another problem can be that the gear selector or PRNDL is not in park. If its not in park the key wont come out.
There is also a brake safety interlock built into these cars that can go hay-wire. The brake saftey interlock is a solinoid that will not allow the vehicle to come out of gear unless the brake is applied and ignition is on.
Worse case the ignition cylinder is bad, and will not release the key.
Try running thru the gears and making sure its all the way in park. Also turn the steering wheel from side to side, see if that makes a diffrence.
SELLC is offline   Reply With Quote
Old 10-17-2009, 11:06 PM   #4
Rewards Points: 12
The problem is a switch on the shifter that is bad. It happened on my sons 01 GP. Only wat to get the switch is a shifter asembly. Look on ebay or used.
norm58 is offline   Reply With Quote
2002 Pontiac Grand Prix Electrical Problem bipper Automotive Repairs 5 07-06-2009 12:06 PM
2002 Saturn Vue Oil in the Coolant brokenhammer Automotive Repairs 3 06-29-2009 01:24 PM
2002 subaru, no power osdhero Automotive Repairs 2 06-25-2009 11:14 PM
2002 Pontiac Grand Prix c.sherry Automotive Repairs 1 06-13-2009 08:15 PM
2002 pontiac grand prix gt electrical stevieb Automotive Repairs 2 11-01-2008 08:32 PM
