2002 Accord Climate Control - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-08-2015, 09:52 PM   #1
Rewards Points: 60
2002 accord climate control
The climate control in my 2002 accord is stuck in the floor vent position. Cannot switch it the upper vents or any other setting.
What is the cause? Advice/step by step instruction on how to fix it?
chhfsc is offline   Reply With Quote
Old 09-08-2015, 11:48 PM   #2
ukrkoz's Avatar
Rewards Points: 930
http://workshop-manuals.com/honda/ac...control_motor/
ukrkoz is offline   Reply With Quote
The Following User Says Thank You to ukrkoz For This Useful Post:
Windows on Wash (09-09-2015)
Old 09-09-2015, 06:30 PM   #3
Bigplanz's Avatar
Rewards Points: 908
http://honda-tech.com/honda-accord-1...frost-2680670/
Bigplanz is offline   Reply With Quote
Old 09-10-2015, 09:43 AM   #4
Brainbucket's Avatar
Rewards Points: 698
On the 4cyl, 6cyl models, there isn't a vacuum line operating the servos. It's all electrical. So first, on the 4cyl models, I would check fuses in the under hood fuse box #41-100amp, #42-50amp, #54-40amp, #56-40amp. Drivers fuse box (inside pass compartment drivers side) #3-7.5amp, pass fuse box (inside pass compartment pass side) #13-7.5 amp. Does blower work? Do fans work? Is this a 4 or 6cyl? The 6cyl check the #41, #42, #54, #56-40amp, #58-20amp, #57-20amp in the under hood fuse box. Drivers side fuse box in pass compartment #6-15amp , #3-7.5amp, and the pass side fuse box in pass compartment #13-7.5amp If all fuses are good and blower works and BOTH cooling fans come on, I know this sounds stupid but does the knob on the control panel feel good? I had one with a bad knob on the control panel not turning the shaft it was on. Those knobs pull right off and you can switch them to see if all's well. They have a metal insert and sometime the plastic will crack. If all is good, get a used control panel and see if that fixes it.
If you first donít succeed, get a bigger hammer!
Brainbucket is online now   Reply With Quote
Wiring fan control relay dougp13 HVAC 14 02-07-2015 02:59 PM
Travertine pavers driveway in cold climate Leopro Concrete, Stone & Masonry 7 01-05-2013 12:06 AM
Boiler Question regarding Pilot Relite Control & Ignition Electrode Assembly stevepatts HVAC 0 02-22-2012 09:42 PM
New control board or fix it? Bobeht HVAC 26 01-18-2012 04:03 PM
Ceiling Fan Speed Control czars HVAC 0 01-14-2010 09:06 PM
