2001 Silverado 2500 Hd - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-22-2013, 02:40 PM   #1
2001 silverado 2500 hd
Truck cranks but wont start.Anyone can help?
kenkan is offline   Reply With Quote
Old 11-22-2013, 04:35 PM   #2
Oso954's Avatar
Rewards Points: 1,332
Get someone with a code reader (and knows how to use it) to read the codes for you. They will then have a good idea of what is causing it.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
kenkan (11-22-2013)
Old 11-22-2013, 06:17 PM   #3
Thanks I just havent found anyone with a code reader yet.
Old 11-22-2013, 09:25 PM   #4
Rewards Points: 1,300
Alex, I'll take ...Bad Fuel Pumps for $500 please
danpik is offline   Reply With Quote
The Following 2 Users Say Thank You to danpik For This Useful Post:
ben's plumbing (11-23-2013), joecaption (12-12-2013)
Old 11-22-2013, 10:19 PM   #5
ukrkoz's Avatar
Rewards Points: 978
Loan code reader from a parts store. It's free.
You asking a question that is impossible to answer. You need oxygen, fuel, spark, and right timing for car to start. Any one of those missing and will be no start.
This is a starting point, pun intended.
http://www.ifitjams.com/starting.htm
Pul a plug out ans smell it. If it smells of gas - you have fuel.
ukrkoz is offline   Reply With Quote
Old 11-23-2013, 01:05 AM   #6
Oso954's Avatar
The two boxes of interest on the chart are "Mechanical distributor - NO" and "Fuel Injection - YES"
Pulling a plug to smell for gas doesn't always work with these engines. The computer won't inject gas unless it thinks the engine will start, so a major malfunction in the ignition shuts off the gas.
Conversely, fuel problems can shut down spark.
Old 11-23-2013, 03:12 PM   #7
ukrkoz's Avatar
Rewards Points: 978
Not to start an argument, but I'd like to see some reference to "computer won't inject gas unless it thinks the engine will start".
Little do I know, but spark follows AFTER fuel was injected and compressed. Unless computer has fortune telling feature built in, which I doubt, as I had 2000 Silverado and it ain't that smart.
Old 11-23-2013, 03:25 PM   #8
Rewards Points: 582
how many miles on it ....or should i say on fuel pump...I have had 6 silverados all with over 100,000 miles ..5 needed fuel pumps... cranking but would not start???????? ben sr
Old 11-23-2013, 04:47 PM   #9
Rewards Points: 40
Can you hear the pump hum when you turn the key to ON (just before START position)? Pounding on the bottom of the fuel tank can sometimes get the fuel pump to start one more time.
daveb1 is offline   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
Old 11-23-2013, 05:53 PM   #10
raylo32's Avatar
Rewards Points: 1,292
Yes, first thing you need to do is get a fuel pressure tester and hook it up to the fuel rail connector. If no fuel pressure, then check the relay but more likely it is the pump.
Live long and prosper.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
Old 11-23-2013, 08:28 PM   #11
ukrkoz's Avatar
Rewards Points: 978
You don't hear pump humm in Silverado. It's too far back and down yonder.
He needs to run diagnostic according to flow chart. If that is done, he will either know what's not working or, will proceed to chasing other venues. Not every Silverado has bad pump. Mine didn't all the way through 148 000 miles, when I sold it.
Easiest is to pul plug out, clean and wipe dry, put it back in, crank engine, and pull plug out. If it does smell of gas - or is fouled with gas - that takes care of this question. If it does not - disconnect fuel line from fuel rail and check if gas is coming out. If it is - there is fuel regulator on that rail, that sometimes goes bad. If regulator is fine, and gas gets to injectors and it's still no start - under good spark condition - it's timing. But timing is ECM controlled via timing chain. So, if it's good spark and fuel is there - it's ECM.
If by any chance security light is flashing continuously - it's BCM acting up and locking fuel supply and ignition.
Old 11-24-2013, 07:41 AM   #12
raylo32's Avatar
Fuel pump hums and whether plugs seem wet or not... that's all just guesswork. Get one of these or similar so you can really figure out what is happening on the fuel side. And even if the gauge reads some fuel pressure, it may not be enough. Make sure to compare it to the spec for your vehicle. I am not sure which motor and FI system you have but some GM CPI (spider injector) motors operate at high fuel pressures and a weak failing pump sometimes will not put out enough pressure to start, even though it seems to be working.
http://www.summitracing.com/parts/an...FU7xOgodOEAA0w
Old 12-06-2013, 04:52 PM   #13
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
Boss's son in law just had to do a fuel pump in a Silverado of this approximate vintage. Take your engine cover off and look for a green cap on the top of the intake manifold, driver's side. You'll see a valve core in it, like on a tire. With the key on, press the core with a small screwdriver. If it doesn't squirt fuel out (and I bet it won't), you have no fuel pressure, and the pump is likely bad.
Mort is offline   Reply With Quote
Old 12-09-2013, 05:38 PM   #14
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,268
I am going to guess fuel pump as well.
Fun little project to drop the tank.
Old 12-11-2013, 11:17 PM   #15
Ummm, if you get fuel out of the evap port (green cap) I would really be surprised...
Fuel pressure test port is on the right side of the intake, on the crossover pipe to the fuel rail. While the fuel pump is the usual suspect, there are also sensors, ground wires, anti theft system faults, fuseblock and/or relay faults, etc, etc, etc....An ounce of proper diagnosis is worth 10 pounds of "spin the wheel of parts."
Lotek is offline   Reply With Quote
The Following User Says Thank You to Lotek For This Useful Post:
cjm94 (12-12-2013)
2001 Chev Silverado will not start polarzak Automotive Repairs 15 01-23-2015 12:31 PM
IC can lights still a problem in my 2001 build? ls3c6 Electrical 2 01-12-2012 01:05 PM
shaking silverado Millertyme Automotive Repairs 6 07-09-2011 09:49 AM
2002 Silverado side view mirror wiring sv9779 Automotive Repairs 1 10-03-2009 07:43 PM
2001 Grand Am Speakers panhandlion Automotive Repairs 3 02-02-2008 05:03 PM
