2001 Mercury Sable Check Coolent Light - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-10-2009, 02:52 PM   #1
Rewards Points: 150
2001 mercury sable check coolent light
My wife's dash warning light keeps coming on Check coolent?
I have checked this out and I have a lot of coolent.
I would like to check the switch or indicator plug
does anyone know where to find this, I could have a bad connection for a start !
deck hand
deck hand is offline   Reply With Quote
Old 07-11-2009, 06:12 PM   #2
More then likely the switch is in the coolant return tank..check the level cold and add as needed
gotboost is offline   Reply With Quote
Old 07-12-2009, 01:14 PM   #3
Rewards Points: 150
HI thanks
I did this. I looked all over the tank area for something pluged in to the tank ? My next step is the old dealer Give me $40.00 dollars and I'll show you !
Deck hand
Old 07-13-2009, 07:23 AM   #4
It's a common problem with thoses years of Tarus/Sable,the switch is in the tank at the bottom,have to remove the tank to get to the wiring,
there is an updated tank and sensor with a clear top,Dorman products sells it about 40 bucks
Old 07-13-2009, 07:40 AM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
I had the same problem when I had an '86 Ford Escort. I ended up just unplugging the sensor and the light turned off.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-14-2009, 08:58 AM   #6
Rewards Points: 150
Thanks Now I know where to look and repair or forget it.
Deckhand
Adding a light to an existing 3-way connection nthomp16 Electrical 2 07-21-2008 06:57 PM
Check Engine light Code P0430 Ford Explorer Mr Chips Automotive Repairs 4 04-09-2008 11:02 AM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 07:06 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
