Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-08-2010, 06:33 PM   #1
Post
2001 GMC VAN - Tail Light Problem
I have a 2001 GMC VAN. When you turn on the head lights the break lights dont work. I have taken apart the rear tail light assembly to do some trouble shooting.
When you take the bulb out of the plug and test the two different contacts (running lights and break lights) they both test fine. When you put the light bulb back in and hit the breaks both lights go out.
It is driving crazy trying to figure this one out. Please help
del.johnston is offline   Reply With Quote
Old 11-08-2010, 07:25 PM   #2
DIY Hack
Mr Chips's Avatar
you have a short somewhere in the wiring, it's probably a piece of bare wire touching the frame somewhere underneath. if you have a trailer harness wired in i'd start there
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 11-08-2010, 08:04 PM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,... Sounds like a Bad Ground at that fixture..
Old 01-13-2011, 10:15 PM   #4
Wiring issue would be the lead culprit for this problem, can be very complicated on certain vehicles might want to check the wiring harness of the Van.
paulrichmond is offline   Reply With Quote
Old 01-14-2011, 12:09 AM   #5
And Still Learning
Resistance.
Corrosion inside of the socket. Take some fine 400 grit sandpaper, wrap it around your finger and clean up the inside of the socket.
Or a bad ground.
Know It ALL is offline   Reply With Quote
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
light fixture removal problem rpavlick Electrical 5 11-19-2009 05:40 PM
Another motion sensing light problem Steelhead Electrical 6 12-24-2008 10:50 AM
Weird Problem with new light.... MRTOWNDRO Electrical 8 12-21-2008 05:00 PM
Problem Installing Track Light MrBill_DIY Electrical 5 11-12-2008 10:35 PM
