2000 Toyota Corolla Trouble Codes. - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-05-2012, 02:40 AM   #1
Rewards Points: 83
2000 Toyota Corolla trouble codes.
I have an engine scanner. The trouble coded I downloaded from my corolla is PO171, PO303, PO304, P0303. My car check engine light has been steadily on for 3 years now Car seems to run fine but gas mileage performance seems to have dropped.
I changed the o2 sensor after the check engine light came on back then. The light went away but came back on a few days after and has remain ON.
REcently I checked the o2 sensor on the voltage. The resistance and voltage were below spec. I notice a suction sound near the radiator. Appreciate any help.
hawaiiboy is offline   Reply With Quote
Old 01-05-2012, 07:38 AM   #2
Rewards Points: 254
You have a lean condition and misfire on cylinders 3&4. Find the sucking noise. Possible vacuum leak causing concern.
cjm94 is offline   Reply With Quote
Old 01-05-2012, 09:38 PM   #3
ukrkoz's Avatar
Rewards Points: 934
Technical Description
System Too Lean (Bank 1)
What does that mean?
Basically this means that an oxygen sensor in bank 1 detected a lean condition (too much oxygen in the exhaust). On V6/V8/V10 engines, Bank 1 is the side of the engine that has cylinder #1.
Note: This DTC is very similar to P0174, and in fact your vehicle may show both codes at the same time.
Symptoms
You will more than likely not notice any drivability problems, although there may be symptoms such as a lack of power, detonation (spark knock), and/or a hesitation/surge on acceleration.
Causes
A code P0171 may mean that one or more of the following has happened:
  • The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
  • There could be a vacuum leak downstream of the MAF sensor.
Possible Solutions
Possible solutions include:
  • In the vast majority of cases, simply cleaning the MAF sensor does the trick. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
  • Inspect all vacuum and PCV hoses, replace if necessary
  • Check for a dirty fuel filter and proper fuel pressure
P0303 Code - Cylinder #3 Misfire
Cylinder #3 Misfire Detected
A P0303 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #3.
Symptoms
Symptoms may include:
  • the engine may be harder to start
  • the engine may stumble / stumble, and/or hesitate
  • other symptoms may also be present
Causes
A code P0303 may mean that one or more of the following has happened:
  • Faulty spark plug or wire
  • Faulty coil (pack)
  • Faulty oxygen sensor(s)
  • Faulty fuel injector
  • Burned exhaust valve
  • Faulty catalytic converter(s)
  • Running out of fuel
  • Poor compression
  • Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
P0304 Code - Cylinder #4 Misfire
Cylinder #4 Misfire Detected
A P0304 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #4.
Symptoms
Causes
A code P0304 may mean that one or more of the following has happened:
  • Poor compression
Possible Solutions
ukrkoz is offline   Reply With Quote
Old 01-13-2012, 10:44 PM   #4
In the absence of a vac leak, mass airflow meters go bad on these once they get past 100,000 miles. I do atleast one a month at my dealership. Not a cheap part, but easy to do yourself with just a Philips screwdriver.
bpodskalny is offline   Reply With Quote
Old 01-25-2012, 09:45 PM   #5
sleepyg's Avatar
The P0303 and 0304 are more than likely a coil pack, just had to replace my number 3 coil pack.
I used to have a handle on life.........................................But it broke!
sleepyg is offline   Reply With Quote
2000 Toyota Avalon: starting and idling problem proofer Automotive Repairs 3 09-03-2008 10:29 AM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 07:31 AM
