2000 Toyota Corolla Pinging And P0171 Code - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-16-2013, 10:24 PM   #1
Rewards Points: 83
2000 toyota corolla pinging and p0171 code
My car has about 175k miles. There is a pinging sound which is pronounce when the car is going up the hill or accelerating. I sometimes get a p0171 OBD-2 code. Don't know why I'm getting a lean condition. Tried to locate a vacuum leak within the front of the engine near the intkake mnifold
hawaiiboy is offline   Reply With Quote
Old 11-17-2013, 08:37 AM   #2
ukrkoz's Avatar
Rewards Points: 952
Your timing is off. Not sure if you have belt or chain, but if belt - was it replaced?
How did you try to locate air leak?
ukrkoz is offline   Reply With Quote
Old 11-18-2013, 11:06 AM   #3
Rewards Points: 83
The car uses a distributorless system so there is no timing adjustment. I basically sprayed brake cleaner near hose connection in trying to find hose leak.
Old 11-18-2013, 05:15 PM   #4
Rewards Points: 1,062
That sometimes is adequate, but abetter method/safer is by ear- take a 1/8" ID plastic tubing, put onto your ear, other end move it around to suspect joints/connections. You will hear a loud/audible hissssssssssssss
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 11-19-2013, 10:24 PM   #5
Lord of Slums
Rewards Points: 1,974
Beginning to think they need a special forum for car problems that are hard to find. If it has a fuel filter I would change that out. I would run some octane boaster and see if that helps. If you have a knock sensor I would look into that. My attitude has become if it runs, drive it. I have spent too much money just having one part after the other changed. A major tune up may help some, that is where you check the compression, adjust the valves, change timing belt, coil packs. Check injector spray
mj12 is offline   Reply With Quote
