-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   2000 toyota corolla pinging and p0171 code (http://www.diychatroom.com/f46/2000-toyota-corolla-pinging-p0171-code-190499/)
hawaiiboy 11-16-2013 10:24 PM
My car has about 175k miles. There is a pinging sound which is pronounce when the car is going up the hill or accelerating. I sometimes get a p0171 OBD-2 code. Don't know why I'm getting a lean condition. Tried to locate a vacuum leak within the front of the engine near the intkake mnifold
ukrkoz 11-17-2013 08:37 AM
Your timing is off. Not sure if you have belt or chain, but if belt - was it replaced?
How did you try to locate air leak?
hawaiiboy 11-18-2013 11:06 AM
The car uses a distributorless system so there is no timing adjustment. I basically sprayed brake cleaner near hose connection in trying to find hose leak.
noquacks 11-18-2013 05:15 PM
That sometimes is adequate, but abetter method/safer is by ear- take a 1/8" ID plastic tubing, put onto your ear, other end move it around to suspect joints/connections. You will hear a loud/audible hissssssssssssss
mj12 11-19-2013 10:24 PM
Beginning to think they need a special forum for car problems that are hard to find. If it has a fuel filter I would change that out. I would run some octane boaster and see if that helps. If you have a knock sensor I would look into that. My attitude has become if it runs, drive it. I have spent too much money just having one part after the other changed. A major tune up may help some, that is where you check the compression, adjust the valves, change timing belt, coil packs. Check injector spray
