2000 Grand Am Blinkers Issue - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-22-2010, 06:36 PM   #1
Rewards Points: 562
2000 Grand Am blinkers issue
I am trying to help my son fix his car a bit. 2000 Grand Am and the blinkers work when it is under 25 degrees. Cold all nite,jump in they work fine. Heater warms up car inside and they quit. When it is over 25 degrees, outside they dont work. Where do you start looking for that problem solution???
4just1don is offline   Reply With Quote
Old 02-22-2010, 09:25 PM   #2
You need a multimeter and a factory wiring diagrams manual which is part of the factory service manuals set for your vehicle. Order from dealer or helminc.com.
Then follow the troubleshooting instructions.
You need this because all the wiring is wrapped in harnesses and it is impossible to trace wires and see where they go. These books tell you which connectors are where specifically, which terminals are what, what wire color is for what, where various components like relays are located, etc.
How to use a multimeter...
http://www.google.com/search?hl=en&s...imeter&aqi=g10
Billy_Bob is offline   Reply With Quote
Old 02-22-2010, 11:01 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,060
Ayuh,... 1st thing I'd do is swap out the Flasher unit plugged into the fuse board....
Cheap 1s are 3./ 4. dollars,.. Better 1s are 5./ 9. dollars...
Old 04-04-2010, 01:30 AM   #4
there was a recall on the blinker or flasher system for 2000 grand ams you might check into it . something that made them mess up and sometimes even come on when they shouldnt be on. hope this helps
internal is offline   Reply With Quote
AC condensate issue cleddy HVAC 1 08-02-2009 09:26 PM
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 07:29 PM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Unusual electrical issue LosLobo Electrical 7 11-10-2008 01:44 PM
