2000 Ford Taurus Misfires - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-10-2013, 04:26 PM   #1
sweaty
Rewards Points: 276
I have a 2000 Ford Taurus Wagon with the ohv engine. It misfires occasionally and gas mileage has decreased to 14-15 mpg lately in suburban driving. It has usually gotten 20 mpg. The heater also seems to take a long time to give out heat.
sweaty is offline   Reply With Quote
Old 02-10-2013, 04:58 PM   #2
Most cost effective way is take it into a shop and have a scan done. If you have not done a full tune up in a while their is no point trying to be a detective.
paintdrying is offline   Reply With Quote
Old 02-10-2013, 10:48 PM   #3
Those engines have a couple of problems. First off is the check engine light on and if it is what are the codes. Could just be a maintenance tune up or could be a mass airflow sensor problem. And for your heat its more likely a clogged heater core. I would ate the heater core lie removed and flush the heater core first. Also have the heater core lines looked at to see if they are rotten and or leaking
Autotech1602 is offline   Reply With Quote
Old 02-10-2013, 11:53 PM   #4
2000 Taurus misfire, etc.....
I've had seven Tauruses from model years '97 up through a 2000. Try the following:
1.Check codes first (OBD II). Take care of those problems(see #2 & #4 below). Cylinder misfire should show up as one of the codes. After resolving code issues, clear the codes.
2.Perform tune up as required. (Also see #4 below)
3.If you are going to pay labor to remove and replace a heater core, Replace the core vs. flushing it and taking a chance. Cores are fairly cheap.
4.Of the seven Tauruses I had, five of those had to have the coil pack replaced. That was the main cause of misfire. Misfiring means that the plugs are not getting spark at the proper time, or not at all, and raw gas has probably ruined the plug(s), and should be replaced.
5. Check for codes again, and so on.....
Good luck with your repairs.
edselsouth1 is offline   Reply With Quote
Too much oil in 2001 ford taurus Shay929 Automotive Repairs 4 11-07-2011 12:25 PM
2000 Ford Focus timeing belt Justinzoila Automotive Repairs 1 10-29-2011 04:18 PM
1994 Ford Taurus engine cut out/died after short time with knock/rattle when using accelerator 94FordTaurus Automotive Repairs 3 06-02-2010 11:53 AM
DIY Question - 2000 Ford Explorer diyford Automotive Repairs 4 01-13-2010 04:20 PM
1997 Ford Taurus GL Tranny econdave Automotive Repairs 3 11-27-2007 12:17 AM
