2000 Dodge Grand Caravan - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-07-2013, 09:11 PM   #1
I've got a manual but I'd like some personal viewpoints please. The turn signals no longer work and I checked the fuses. They're all good. What else could be causing this problem?
Metro is offline   Reply With Quote
Old 04-07-2013, 10:59 PM   #2
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Flasher? Switch? Bulbs?
I hate signatures.
Mort is offline   Reply With Quote
Old 04-07-2013, 11:07 PM   #3
I checked the fuses? You need to check where you are getting power. Are you getting power where the fuses plugs in? Where does the power stop. If the bulbs are not blinking are they getting power. Go buy yourself a 5 dollar test probe.
paintdrying is offline   Reply With Quote
The Following User Says Thank You to paintdrying For This Useful Post:
r0ckstarr (04-08-2013)
Old 04-08-2013, 06:59 AM   #4
DIY staff
Rewards Points: 7,174
turn signals will not work if you have bad light bulbs---start by changing the bulbs.
Old 04-08-2013, 09:00 AM   #5
Lord of Slums
Rewards Points: 1,974
Light bulbs can be a good place to start. Generally a turn signal will blink faster if one of the bulbs burns out. Your Dodge has a lot of mickey mouse stuff making it harder to trouble shoot
mj12 is offline   Reply With Quote
Old 04-08-2013, 09:03 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
Check fuses, relays, get a tester, and check the lights.
Usually a fuse will take both sides with it. If it is only one side, its a bulb issue.
Old 04-08-2013, 10:48 PM   #7
Checked both bulbs and the one on the driver side was toast. Bought a new set and replaced the bad one, and that was when I saw that the assembly it latches onto was browner than it should be. I think that whole connection is fried. I'll take it in tomorrow and replace it. Hopefully this will fix it.
The Following User Says Thank You to Metro For This Useful Post:
oh'mike (04-10-2013)
General and Specific Questions on Clutch Replacement 2000 Celica GTS amodoko Automotive Repairs 24 02-25-2013 02:59 AM
2000 Ford Taurus Misfires sweaty Automotive Repairs 3 02-10-2013 11:53 PM
2000' underground to house? russplmb2 Electrical 15 01-31-2012 12:17 PM
2000 Dodge Ram Roofmaster417 Automotive Repairs 4 01-31-2011 02:27 PM
System 2000 Barry J HVAC 0 10-17-2010 09:55 AM
