Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-18-2011, 08:25 PM   #1
2 cycle engine no spark
I've got an old Mac 2816 that has no spark. Initially I tried changing the spark plug with no result. Next I disconnected the kill switch, (which had a small fray on the insulation of the wire going to it. I still got no spark when I cranked it. At this point I suspected either a worn or sheared flywheel key or a faulty ignition module. Both the key, and the keyway were in good shape, showing no wear, or deformity. Finally I was able to find a new ignition module for the machine, (no small feat in itself), but after swapping out the old one, I still have no spark.
Since I had the recoil start housing off the machine I spun the engine using an industrial electric dril at approx 175 rpm.
It's a pretty simple circuit, with no interlocks or anything that I'm aware of. As a result, I'm stumped. Does anyone out there have any new ideas I can try?
walkinman is offline   Reply With Quote
Old 06-20-2011, 10:44 AM   #2
Not sure, but I'm thinking that the "kill switch" is simply a ground, so you disconnected it, but did you repair or replace the frayed wire? If not, it seems that could be your problem.
Old 06-20-2011, 06:25 PM   #3
It's also possible that you bought a defective module. Just because it's new doesn't mean it's good
rustyjames is online now   Reply With Quote
Old 06-20-2011, 11:12 PM   #4
when you say ignition module do you mean coil? if so did you use a feeler gauge to set the gap from the magneto to coil?
oldrivers is offline   Reply With Quote
2 cycle engine problems noquacks General Discussion 10 07-28-2011 08:32 AM
2 Cycle Engine Repair TJ_in_IL Tools 1 11-09-2010 02:12 PM
improved 2 cycle engine oil? oletrkguy Landscaping & Lawn Care 0 11-08-2009 12:50 PM
Kawasaki FE-350 11.5hp 4 stroke engine wings3630 Landscaping & Lawn Care 2 08-05-2008 07:08 AM
