-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   2 cycle engine no spark (http://www.diychatroom.com/f46/2-cycle-engine-no-spark-108229/)
walkinman 06-18-2011 07:25 PM
I've got an old Mac 2816 that has no spark. Initially I tried changing the spark plug with no result. Next I disconnected the kill switch, (which had a small fray on the insulation of the wire going to it. I still got no spark when I cranked it. At this point I suspected either a worn or sheared flywheel key or a faulty ignition module. Both the key, and the keyway were in good shape, showing no wear, or deformity. Finally I was able to find a new ignition module for the machine, (no small feat in itself), but after swapping out the old one, I still have no spark.
Since I had the recoil start housing off the machine I spun the engine using an industrial electric dril at approx 175 rpm.
It's a pretty simple circuit, with no interlocks or anything that I'm aware of. As a result, I'm stumped. Does anyone out there have any new ideas I can try?
DexterII 06-20-2011 09:44 AM
Not sure, but I'm thinking that the "kill switch" is simply a ground, so you disconnected it, but did you repair or replace the frayed wire? If not, it seems that could be your problem.
rustyjames 06-20-2011 05:25 PM
It's also possible that you bought a defective module. Just because it's new doesn't mean it's good :thumbsup:
oldrivers 06-20-2011 10:12 PM
when you say ignition module do you mean coil? if so did you use a feeler gauge to set the gap from the magneto to coil?
