1999 Chrycler LHS 3.5 L - A/C - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-30-2014, 09:00 AM   #1
Rewards Points: 1,989
Last summer , I helped a cousin replace o-rings on the lines , at the compressor and tried to replace the Schrader Valves at the service ports . The Schrader Valve are medium size , not the small ones , like those in tire / wheel valve stems .
We could not find replacement Schrader Valves . We vacuumed the system down and recharged with R-134a , by weight .
It leaked back down in about 3 days .
Friday , we started working on it again . Removed the compressor an my cousin bought a new one at O'Reilly Auto Parts . Found o-rings and Schrader valves at NAPA . The compressor does not come with the high / low pressure manifold . Replaced the Schrader valves , at the manifold , and the new gasket ( that came with the compressor ) between the compressor and the manifold .
All the while , we were looking for oil leaks , any where on the parts of the A/C system . That we could see & trace down . There was no oil in then old compressor . Added 5 ounces of PAG 46 .
Installed the compressor and 2 new belts . Installed the 2 refrigerant lines with the new o-rings .
Vacuumed the system down for 2 hours , to about 29 mm of mercury . Gassed it back up with R-134a . At about 50 - 60 mph , vent discharge temp was around 45 F . Very pleased with that , but still concerned about leaks . But only time will tell .
God bless
Wyr
WyrTwister is offline   Reply With Quote
Old 04-18-2014, 07:10 PM   #2
Rewards Points: 1,062
OK, hope it holds, but you didnt say if, after you vacd it, if you watched the needle for movement over say, 15 minutes. Not that that is the only/best way to check for leaks. Pressurizing is the best way.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 04-18-2014, 11:14 PM   #3
Yes , it held vacuum . Last time we worked on it , it held vacuum for at least 2 days . ( My cousin was in the hospital , for a procedure , for that period of time . )
Unfortunately , it has now leaked down , to the point of not cooling , both times . In 2 - 3 days .
Could see no evidence of dye leaking , anywhere forward of the fire wall . Our guess is a leak in the evaporator or at the gasket where the evaporator flange bolts to the " back side " of the expansion valve ?
Thanks ,
Wyr
God bless
Old 04-19-2014, 12:01 AM   #4
Rewards Points: 254
Evaporator cores are not uncommon in that car
cjm94 is offline   Reply With Quote
Old 04-19-2014, 12:41 AM   #5
You mean , leaks in the Evaporator cores ?
Thanks ,
Wyr
God bless
Old 04-19-2014, 06:54 AM   #6
Rewards Points: 254
Originally Posted by WyrTwister
You mean , leaks in the Evaporator cores ? Thanks , Wyr God bless
. Yes
Old 04-19-2014, 09:37 AM   #7
Thanks , :-)
Any advice on getting to and possiably removing the evaporator ?
God bless
Wyr
Old 04-19-2014, 11:32 AM   #8
Rewards Points: 254
You need to remove the dash to get to it. Get a manual and take your time and they are not to bad a good days project. 2 if your not real familiar with that work. Book time is about 8 hours for someone who does it daily
Old 04-19-2014, 12:10 PM   #9
Thanks , will pass this along to my cousin . He lives one state ( 6 - 8 hours ) away and , unfortunately , can not just drop by to help each other with these projects . :-(
God bless
Wyr
Old 04-21-2014, 07:22 PM   #10
Wyr, sorry for delay, but dang- I did one of those on my 99 voyager!!! Now, big question- is that the ORIGINAL evap?? If so, good chance it IS the evap. Thos stinkin light weight aluminbum evaps, didnt last for beans. Full of pin holes. I injected dye in mine (with some refrigerant), and opened up the glove box (dont remember exactkly how), and saw the fluorescent dye on the alum fins!!
Yup, its a weekend project, maybe more. One tip- beware of the elusive last hex nut to loosen on the evap black box- its from the engine bay side. I yanked for so lomng on the case, never came out until I stumbled on that last "hidden" nut.
Good luck, man.
Old 04-21-2014, 07:27 PM   #11
Oh- beware of the air bag system clock spring- very dangerous. Forget just how to temporarily disable it, maybe some one here can help......I just proceeded slowly. Steering wheel has to be loosened. Maybe I pulled the fuse to clockspring(?)
Old 04-21-2014, 08:01 PM   #12
Rewards Points: 254
[QUOTE="noquacks"]Oh- beware of the air bag system clock spring- very dangerous. Forget just how to temporarily disable it, maybe some one here can help......I just proceeded slowly. Steering wheel has to be loosened. Maybe I pulled the fuse to clockspring(?)[/QUOTE No need to pull steering wheel pull the whole column in one piece. Tape wheel so it doesn't spin when you remove the lower shaft. Unhook the battery and wait 5-10 minutes and airbag is disabled.
Old 04-22-2014, 12:23 AM   #13
Thanks ,
Wyr
God bless
1999 Geo Tracker over-heating. Where is the temperature sensor? texangolfpro Automotive Repairs 2 08-30-2012 01:15 AM
1999 Cheverolet Camoro Roofmaster417 Automotive Repairs 0 01-12-2011 06:54 PM
