Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-15-2010, 08:53 PM   #1
1998 Isuzu Rodeo Repair Manual
I just bought a used Rodeo and am looking for a Chiltons for this year and model. I have the Haynes but they are never as detailed as the Chiltons. Any ideas where I can find one? The closest year I can find is '96.
Thanks for the help!
TJMS81 is offline   Reply With Quote
Old 12-15-2010, 10:37 PM   #2
DIY Hack
Mr Chips's Avatar
if you can't easily find it, it's likely that they didn't offer one for those model years
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 12-16-2010, 05:47 PM   #3
That's what I was thinking but hoping not.
Old 12-16-2010, 06:50 PM   #4
Ok, hopefully someone on here can help me then...the hood release cable is not releasing the latch so I can access the motor. Haynes just shows how to replace it. I haven't tried removing the handle an pulling on the cable with some pliers but that is what I was going to try next unless some has a better idea.
Old 12-17-2010, 09:27 PM   #5
DIY Hack
Mr Chips's Avatar
yea, grab a set of vice grips, lock down on the cable and pull. that should do it, but if not, get someone to lift up on the hood while you pull on the vice grips.
if these fail, crawl under the front end and try to reach up and release the latch manually
Old 12-19-2010, 11:41 AM   #6
Household Handyman
My son has a '95 Isuzu Rodeo, so I'm speaking from "hands-on" experience--my hands-on it. You can release the hood by reaching through the grill with a long, sturdy screwdriver while someone presses on the front of the hood to release tension. Once you have the hood open: Find where the cable attaches to the hood release mechanism. Then using a pair of pliers, pull the cable OUT some, it won't move much, but this will show you how much the cable has stretched over time. The fix: Simple, using large lead fishing line weights which have the slot in them, put them on the cable to reduce the excess cable. Crimp them really tight. This is how I fixed my son's when this happened to his. Now: IF this has the V-6 and you ever have water coming from in back of the crankshaft pulley for the serpentine belt---changing out the water pump is NO fun at all. Good Luck
Oh and--Chilton's and Haynes manuals have an address in them to order the book for your vehicle, there may even be a phone number listed.
Old 12-19-2010, 12:40 PM   #7
Drywall contractor
Go on Ebay or even just Google. Type in automotive service manuals. I actually buy the factory service manuals for my vehicles as they're way more complete (3 & 4 volumes), but there are lots of Haynes and Chilton books available.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 12-19-2010, 06:31 PM   #8
Thanks everyone for your advice. Now, I have to clean out the garage to fit a vehicle into it. The other option is crawling working in 2.5 ft of snow.
Old 12-19-2010, 06:46 PM   #9
Drywall contractor
I think I'd clean out the garage....
Old 12-22-2010, 12:17 AM   #10
Me too.
Old 12-22-2010, 08:31 PM   #11
Seasoned DIYer
Check the public library. The ones around here have quite a few Chilton/Hayne's manual.
HVAC_NW is offline   Reply With Quote
Old 12-26-2010, 11:16 AM   #12
Licensed P.E./Home Insp
Aggie67's Avatar
I've been a subscriber to an on-line manual outfit for a few years. It's worth it because you get all the service bulletins. Also really good exploded views, and good step by step procedures.
Aggie67 is offline   Reply With Quote
Old 12-26-2010, 05:52 PM   #13
Thanks everyone for the suggestions! I ended up pulling the cable with vise grips then using the slipshot fishing weights to hold tension. Super idea!
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
repair manual netjunky65 HVAC 0 10-14-2009 11:52 PM
99-02 Silverado Repair Manual...? jaysen Automotive Repairs 6 09-24-2008 02:01 PM
