1998 Ford Ranger - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-13-2011, 06:29 PM   #1
1998 ford ranger
I do not have any instruments like oil pressure, fuel tach and speedometer. I have checked all the fuses and they are ok. Anyone have any ideas??
Joe Casey is offline   Reply With Quote
Old 03-13-2011, 07:34 PM   #2
ukrkoz's Avatar
Rewards Points: 952
meaning, you have them, but they quit working? suddenly? any signs before it happened? any "last jobs"? lightening? battery changes?
ukrkoz is offline   Reply With Quote
Old 03-13-2011, 07:40 PM   #3
well we lost tail lights and the fuse was blown under the hood. then one of the fuses in the panel wasnt making contact so we had to take all the fuses out and reoair the contact. the battery was replaced as well, After we replaced the battery it wouldnt start and the 25 amp fuse was blown. it runs now, we have tail and dash lights but no instruments.
Old 03-13-2011, 07:43 PM   #4
ukrkoz's Avatar
Rewards Points: 952
so you have a loose wire somewhere after that job. pretty obvious. you need electrical diagram and chase it down now. or, be lucky, get to them again, and maybe it's right in you face one. knowing gremlins that live in the wires, slim to none chance.
a wire could have been torn also, or ripped out. sounds like a lot of messing under the dash was done. just make sure you have battery absolutely disconnected, or you may fry something else.
Old 03-14-2011, 10:07 AM   #5
Learning Things Every Day
Jay 78's Avatar
I'm not sure if you're an "enthusiast" as you'd probably already be a member of a Ranger forum and therefore more likely to have posted your question there than here, but from one Ranger owner to another, I suggest signing up here: http://therangerstation.com/forums/
Ask any question and you will get your specific answer.
Under Construction
Jay 78 is offline   Reply With Quote
The Following User Says Thank You to Jay 78 For This Useful Post:
ukrkoz (03-14-2011)
Old 03-14-2011, 04:17 PM   #6
Sounds like you need a cluster. Might want to take it out and check to see if your getting power to it. If you get a new cluster from a junk yard.
MatthewTL is offline   Reply With Quote
Ford Ranger Thermostat Problem? suzikg Automotive Repairs 21 04-18-2014 10:54 AM
93 Ford Ranger A/C problem robcourtis Automotive Repairs 1 06-14-2010 09:20 PM
1988 ford ranger 2.3l Justin25 Automotive Repairs 1 04-14-2010 11:57 AM
1997 ford ranger running hot gclark0024 Automotive Repairs 5 06-19-2009 04:47 PM
1998 Ford ranger electric problem fmg741 Automotive Repairs 5 09-24-2008 12:24 PM
