1997 Ford Ranger Running Hot - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-18-2009, 03:21 PM   #1
1997 ford ranger running hot
I have a 3.0L ranger that started running hot and boiling over. I changed the thermostat but that doesn't seem to help. Sometimes it will run hot and you can let it cool down then it may not run hot for days and then it happens again. Whats up?
gclark0024 is offline   Reply With Quote
Old 06-18-2009, 06:04 PM   #2
Particles intermittently clogging the cooling system?
Old 06-18-2009, 10:44 PM   #3
The easiest things to check would be: 1) Is the radiator fan working? and 2) Check the coolant level and strength
kchopper is offline   Reply With Quote
Old 06-19-2009, 08:15 AM   #4
Kinda Handy
check rad cap is all I can think of,make sure all of your hoses are in good shape, maybe check the water pump, take drive belt off and wiggle pulley in all directions including in and out if there is any play replace the pump. did you put the stock temp rated thermostat in it when you replaced it and did you put it in right side up? im going to bet on the radiator cap and what kchopper said that covers 95% of the cooling system
Suzuki91vx800 is offline   Reply With Quote
Old 06-19-2009, 08:16 AM   #5
The fan seems to be working and the coolant level is good.
Old 06-19-2009, 04:47 PM   #6
I'd run LED monitors to make sure the fan is not intermittent and monitor anything else electrical having to do with temperature. Next time it overheats you'll know if it is an electrical problem.
You have a better chance of finding this if you can induce the problem.
Ford Ranger Thermostat Problem? suzikg Automotive Repairs 21 04-18-2014 10:54 AM
1997 ford expedition remote sgtrock Automotive Repairs 13 02-10-2009 07:53 AM
'93 Ford Ranger help Sharpeone Automotive Repairs 9 12-28-2008 08:16 AM
1998 Ford ranger electric problem fmg741 Automotive Repairs 5 09-24-2008 12:24 PM
1997 Ford Taurus GL Tranny econdave Automotive Repairs 3 11-26-2007 11:17 PM
