1997 Ford Expedition Remote - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-05-2009, 07:16 AM   #1
1997 ford expedition remote
I had a dead battery on this vehicle the other day and now the remote won't lock or unlock the doors. The key also won't unlock either of the front doors and hasn't for years.Is there programming instructions for the remote? And why won't the key work in the front door locks!
sgtrock is offline   Reply With Quote
Old 01-05-2009, 10:18 AM   #2
Rewards Points: 274
Assuming you haven't locked yourself out the following are the programming instructions for 97 and up. No idea why the key itself will not work...maybe try some WD40.
  1. Insert a key in the ignition and turn from 3(Off) to 4(On) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 4(On) position.
  2. The doors will lock/unlock to confirm that programming mode has been entered.
  3. Within 20 seconds, program a remote transmitter by pressing any button on a transmitter. The doors will lock/unlock to confirm that the remote transmitter has been programmed. (If more than 20 seconds pass before pressing a remote transmitter button, the programming mode will exit and the procedure will have to be repeated.)
  4. Repeat the previous step to program additional remote transmitters. The doors will lock/unlock to confirm that each remote transmitter has been programmed.
  5. When you have completed programming the remote transmitters, turn th ignition to 3(Off) or wait 20 seconds. Again the doors will lock/unlock to confirm programming has been completed.
Good luck
polarzak is offline   Reply With Quote
Old 01-05-2009, 02:31 PM   #3
Thanks a lot,that worked great!
Old 01-06-2009, 08:39 PM   #4
Safe, Most of the Time!!
brokenknee's Avatar
What is the 3 and 4 position? Is the 3 position the regular off position? and the 4 position the run position?
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 01-06-2009, 09:03 PM   #5
brokenknee's Avatar
Just went out to try to program my 2002 F150 so it would work off the remote starter for the wife's car. Tried using the aux button we do not use.
I could not get it to work. Turned the key off and on 8 times, the locks did lock and unlock. When I pressed the aux button nothing happened. The light did flash on the remote, but the power locks did not lock and unlock.
Any thoughts?
Old 01-08-2009, 01:29 PM   #6
K&B Remodeler/Tile Guy
angus242's Avatar
#1 = OFF (where the cylinder is when you remove your key)
#2 = AUX (the position when you power the electrical devices [power windows] but the vehicle isn't running)
#3 = RUN (the position the key is in AFTER you start the engine and release the key)
#4 = START (When you engage the starter to get the engine running)
Angus
My Albums
angus242 is offline   Reply With Quote
Old 01-08-2009, 02:03 PM   #7
brokenknee's Avatar
Thank you, any idea why I can't program the aux button on my wife ford focus remote starter to work with the locks on my ford f150?
Old 01-08-2009, 02:25 PM   #8
angus242's Avatar
I am not familiar with a Ford remote that has an AUX button. Most older remotes look like this:
or without the blue button for a vehicle with no trunk.
Angus
My Albums
Old 01-08-2009, 03:40 PM   #9
brokenknee's Avatar
It is an aftermarket for her remote starter.
Old 01-09-2009, 06:38 AM   #10
Rewards Points: 274
That may be the problem. The instructions I posted were for OEM remotes.
Aftermarket remotes normally come with an instruction manual, or if not, they probably have a website where you can download manuals.
Old 01-09-2009, 07:48 AM   #11
brokenknee's Avatar
Thank you. I will look and see what I can find on the internet.
Old 02-09-2009, 12:10 PM   #12
Craftsman
what years of fords does this programming work for?
Superrick is offline   Reply With Quote
Old 02-09-2009, 01:58 PM   #13
Rewards Points: 274
From the second post
Old 02-10-2009, 08:53 AM   #14
Craftsman
Thanks, I need an extra remote for a 2003, think I'll call the salvage yard today!
Remote with whole house fan? jman1 Electrical 11 05-23-2010 10:07 AM
Missing Wireless Remote - Motorized Plasma TV Lift JanFan Home Theater 3 03-19-2009 09:46 AM
Hampton Bay Remote Ceiling Fan esqjd Electrical 16 01-14-2008 06:32 AM
Genie garage door remote Bull-37 General DIY Discussions 2 01-10-2008 08:56 PM
1997 Ford Taurus GL Tranny econdave Automotive Repairs 3 11-27-2007 12:17 AM
