1996 Pontiac Grand AM Instrument Cluster Change - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-08-2009, 07:41 PM   #1
1996 Pontiac Grand AM Instrument Cluster change
I have a V6 1996 Grand AM SE with bad Instrument Cluster that needs to be replaced. I can't seem to find any used one for the particular year. But I do see one on ebay for 97-98 grand am models that look exactly the same. On the other hand, those listed under 94-95 models look different.
Do the 97-98 instrument clusters work with 1996 Grand Am? Thanks a bunch.
turbolover is offline   Reply With Quote
Old 05-09-2009, 07:22 PM   #2
I would start by checking with a reputable salvage yard to see if it's compatable. Your local pontiac dealer may be able to help as well. One problem could be different options, such as engine and trans combinations, gage packages etc. I would be nervous buying a used cluster on e-bay. Even if it's the right one, it may not be any better than the one you have. There might still be rebuilt unit available through a speedo shop. Check with your G.M. dealer. Most exchange units aren't that exspensive. I can't remember if that old of a cluster would need to be programmed once installed. Here again, check with a dealership..
frazierdavidson is offline   Reply With Quote
Old 05-18-2009, 11:00 PM   #3
G_P
96-98 models should all use the same parts.
G_P is offline   Reply With Quote
Old 10-27-2010, 08:58 PM   #4
huynh's Avatar
If I need to buy used parts online, this is where I ordered most of the time:
http://www.car-part.com/
When you enter the year of your car, it will show comparable parts from the other years for you too.
huynh is offline   Reply With Quote
Old 10-27-2010, 09:38 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
Good site. I have bought a lot of parts for my 89 Riviera there.
