1996 Dodge Caravan Overheating Problem - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-15-2009, 12:09 PM   #1
1996 Dodge Caravan Overheating problem
Hi,
My 1996 Dodge caravan overheats when I am stalled on the road for about 10 minutes. When this happens a check engine light pops on on my dashboard. Anyone have an idea what is happening and how I can fix this?
benlee is offline   Reply With Quote
Old 08-15-2009, 12:38 PM   #2
Oldguy
Rehabber's Avatar
If it does not overheat at any other time. my best guess with the limited information provided, is that the radiator fan(s) is not coming on. Let the car idle until hot and see if the fans come on. If not, turn on the A/C and see if the fan(s) come on. If not, you have a bad fan motor(s) or bad relay.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 08-15-2009, 09:56 PM   #3
Thanks for your help, I suspected that there was a fan problem too. I will go get it checked and see if I can fix it.
Old 08-15-2009, 10:27 PM   #4
Registered User
Rewards Points: 526
I have a '92 P.V. The fan wires shorted once, down at the fan motor. My relay shorted once. The starter relay, third back on the right side, failed 4 times over 10 years. The serpentine belt last about two years, buy the clogged one, much better. The abs light comes on when the brake fluid reservoir is low, be sure to read the manual. (Pump them 40-50 times before topping off. You can read the codes by counting the flashes then compare to any manual. Mine stalled after a 10 minute drive, repeatedly. End result, when the seasons change, the gunk in the throttle air body makes the choke vane stick closed. Spray carb. cleaner through a fitting hole from the sending unit before the chamber. (They are not made for trailers)
Be safe, G
dodge cummins starting problem 89 colddodger Automotive Repairs 2 12-31-2008 03:11 AM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
Dodge Caravan 2005 driver door lock Wildie Automotive Repairs 11 11-20-2008 03:18 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
