1995 Olds 98 Heater Problems - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-15-2012, 02:48 PM   #1
Rewards Points: 27
1995 olds 98 heater problems
I disconnected the battery on my Olds 98 in order to change out the starter and now I don't have any heat. It was working fine before. I suspect it is something to do with the computer resetting but it has been 2 weeks and still the same. Sometimes I get heat and sometimes I get heat from one place and cold out of another vent. I suspect the computer because it took the radio a while to reset. Is there a way to get the computer back in sinc?
ROBBYT3 is offline   Reply With Quote
Old 03-15-2012, 03:55 PM   #2
Rewards Points: 104
Not an expert, but being a bit doubtful of the problem being computer related, I would first check to see if there is a disconnected or damaged vacuum line.
Old 03-15-2012, 04:17 PM   #3
Rewards Points: 27
How do you go about checking vacuum lines?
Old 03-15-2012, 10:53 PM   #4
Rewards Points: 104
I would start with a thorough visual inspection under the hood. It takes a tight seal to pull a vacuum, and vacuum hose should be relatively soft and pliable, not hard and cracked or brittle, so you can do a pretty good job with sight and feel. And, since you suspect that it happened at the same time that you replaced the starter, retrace your steps, and focus on areas where you might have reached through with a wrench, or whatever, and possibly bumped something. After that, with the engine running, transmission in park, and parking brake engaged (assuming that you use it once in a while, otherwise don't engage it, or you might have something more to repair) I would lay down on the floor of the car, with my head as far under the dash as possible, and reach up and operate the heater controls. There are doors within the ducts under the dash, which route your heating and cooling to the floor, dash, or wheever you set it. Those doors are typically vacuum actuated, which is the reason for starting with vacuum lines under the hood, and you should be able to hear, or by laying a finger against various areas of the duct, feel, whether or not the doors are operating. Again, I'm not saying that your first inclination is not right, and that it's not a computer controlled system, but this is how I would first approach it.
The Following User Says Thank You to DexterII For This Useful Post:
Marty1Mc (03-17-2012)
Old 03-18-2012, 02:31 PM   #5
Try a "reboot"!
Remove a battery terminal for 10 minutes, then reconnect.
Turn ignition switch to on, but don't start.
Wait 1 minute.
DO NOT touch any buttons in the vehicle during this minute.
Then start vehicle and let idle for 5 minutes.
This "reboots" the A/C which then "resynchronizes" the actuator doors during the power-up.
Billy_Bob is offline   Reply With Quote
Old 03-19-2012, 09:32 AM   #6
Rewards Points: 27
Thank you! I will try this when I get home today!
Wire gauge for water heater and rewiring poesprogeny Electrical 15 11-18-2011 06:22 AM
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 09:12 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Problems with water heater jwise Plumbing 11 02-26-2010 07:36 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 03:53 PM
