1995 E-van Shifting Issues - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-28-2010, 01:15 PM   #1
Home Performance
HomeSealed's Avatar
Rewards Points: 710
1995 E-van shifting issues
I have a 1995 Ford E15o with a 6cyl and 90,000 miles. It runs like a top. The problem is when its cold, the tranny slips real bad. It feel like I'm running a super high stall convertor with a shift kit or something. Usually within 5-10 min of warming up and/or driving, it shifts perfectly smooth. I'm kinda thinking its a Torque convertor issue? Any ideas? Fluid is full and clean.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-28-2010, 02:56 PM   #2
Oldguy
Rehabber's Avatar
Drop the pan, change the filter, and add a can of K&W Trans-X before refilling with MerconV fluid.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-28-2010, 08:42 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 710
The filter/fluid aren't that old. What is the basis of your recommendation?
www.HomeSealed.com
Old 01-28-2010, 10:35 PM   #4
I have rebuilt many automatic transmissions. Depending on how a vehicle is operated has a great influence on equipment life. With age and/or heat, all the rubber seals get hard and will not seal properly when cold. After they heat up, they will be softer and seal better. A rebuild is likely in need but you can extend tha time a little with a bottle of Lucas automatic transmission additive.
I never recommend "snake oils" to anyone but I don't consider any of Lucas products to be snake oils. I have used nearly every product Lucas makes with good results.
NO I don't own stock with Lucas.
Giles is offline   Reply With Quote
Old 01-29-2010, 09:33 AM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Thanks for the tip
www.HomeSealed.com
Old 01-29-2010, 11:34 AM   #6
Oldguy
Rehabber's Avatar
If you have a fresh filter, then add a can of trans-x to cut the likely varnish build up in the valve body. I have seen this save a LOT of transmissions. Lucas has its purposes, but I don't believe it will help you in this situation.
Leak Issues Bill65 Roofing/Siding 2 11-02-2009 09:47 AM
Basement wall issues. Need rough idead of fix. meltdowndave Building & Construction 6 10-03-2009 12:24 PM
Issues with tile...any help is appreciated blinky44 Flooring 5 07-28-2009 12:58 AM
Ice dams issues faller Roofing/Siding 16 01-24-2009 05:02 AM
Hi from middle TN 1940s house issues kscudebec Introductions 1 01-09-2009 06:56 PM
