1995 Dodge Caravan "SHAKEIN" - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-12-2009, 08:32 AM   #1
frustrated
grumpypapa's Avatar
My caravan shakes at 55 mph and over. I know what ur thinking tires off balance, bent rim ................checked all of that and all seems fine. now the kicker that causes me too wonder. When accelerating at 55 +or holding the throttle steady at 55 + it shakes let of the gas and smooth as silk ????????????????????? any suggestions
grumpypapa is offline   Reply With Quote
Old 02-12-2009, 09:11 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,368
Ayuh,..
Sounds like a Transmission/ Axle problem...
Old 02-12-2009, 11:28 AM   #3
frustrated
grumpypapa's Avatar
Thumbs up
both half shafts were just replaced but seems to have an o/d shifting prob tho
Old 02-18-2009, 10:01 PM   #4
It could be caused by a number of different things. Most often it is a rim/tire problem. Did you just have the wheels balanced? How much weight did they have to use? Other likely cause would be the alignment, tie rod ends, or slop in the wheel bearing.
danr44 is offline   Reply With Quote
Dodge Caravan 2005 driver door lock Wildie Automotive Repairs 11 11-20-2008 03:18 PM
Dodge Minivan Transmission STEPHENWANGEL Automotive Repairs 4 02-19-2007 07:14 PM
