1990 Ford 4x4 - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-01-2013, 01:20 PM   #1
Rewards Points: 164
1990 ford 4x4
Have a oil pan gasket leak and need to change the gasket looks difficult there's a cross member in the way, a lot of people say to lift engine is there another way HELP!!!
bostonwindows30 is offline   Reply With Quote
Old 12-01-2013, 03:19 PM   #2
That is the only way I know it can be done.
big juicy01 is offline   Reply With Quote
Old 12-01-2013, 03:26 PM   #3
Rewards Points: 164
So what do I need to so??
Old 12-01-2013, 05:01 PM   #4
Rewards Points: 164
How should I do this?? Need help
Old 12-01-2013, 05:30 PM   #5
Remodeler
Rewards Points: 320
The safest way is to pick the engine up and hold it with an engine hoist. The engine may have some lifting points at the front and rear of the intake or heads. You may need to remove the intake plenum on the top of the intake manifold. If you don't have lifting points, use a short section of chain. Assuming you have a V8, bolt it securely to the front of one head and rear of the other, then connect the hoist to that.
Disconnect the engine mounts , remove the fan shroud and carefully lift the engine. Watch for binding as you lift, especially at the rear where you will lift the engine up to contact the firewall. When you have reached the maximum lift without binding you must stop. If you can remove something to gain a bit more clearance that also may be necessary.
Even after lifting, the clearance may be very tight. Often after dropping the pan you may need to reach inside the pan and disconnect the oil pump pickup in order to get the pan out.
I caution against trying to do this without a hoist, using a jack and blocking can work, but if the engine slips you could become pinched and trapped resulting in serious injury. I like to use a hoist but also place blocks between the engine mounts and frame for extra safety when possible.
iamrfixit is offline   Reply With Quote
Old 12-01-2013, 05:43 PM   #6
Sounds like a job for a mechanic. Back in 2000 we paid 1200 for a mechanic to do that. I worked at Walmart in the tire and Lube. Needless to say paid it more than once
Old 12-01-2013, 05:55 PM   #7
Rewards Points: 164
All this work for a leaking gasket, unreal...
Old 12-01-2013, 05:56 PM   #8
Rewards Points: 164
Thank you guys greatly appreciate this, never lifted a motor before do you have a video?
Old 12-01-2013, 06:20 PM   #9
ukrkoz's Avatar
Rewards Points: 946
Good luck
http://www.autozone.com/autozone/rep...96b43f8038ebd5
ukrkoz is offline   Reply With Quote
Old 12-01-2013, 06:21 PM   #10
ukrkoz's Avatar
Rewards Points: 946
Btw, one can safely raise engine with jackstand and main pully as attachment point. Just make sure jack is dead center on pulley and use solid board as interface.
Old 12-02-2013, 06:51 AM   #11
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,042
Ayuh,.... The Odds are, once ya pull the motor, 'n get the oil pan off, you'll find it's rusted through, 'n it's not the gasket at all....
Fords are notorious for Rotten oil pans,...
Bondo is online now   Reply With Quote
Old 12-02-2013, 04:18 PM   #12
Rewards Points: 164
Okay noticed something feel like a dumb ass, my truck has a 6" lift on it think I can clear it???
Old 12-02-2013, 04:23 PM   #13
Rewards Points: 77
Even with your 6" lift, I think the cross member will still be in the way. Usually it is part of the frame. Good Luck
cyberknight is offline   Reply With Quote
Old 12-02-2013, 04:27 PM   #14
Rewards Points: 164
Can I take the cross frame out?
Old 12-02-2013, 04:29 PM   #15
Remodeler
Rewards Points: 320
The engine sits in the frame the same way with or without a lift so you will still have to raise the engine to clear the cross member. The entire front section of the frame is welded, so no removing it.
The extra lift might make it tougher to reach over the radiator support with an engine hoist, although probably still possible.
You could remove the front wheels, lower it down and set it on jack stands or simply air the tires down to drop it lower.
Is it all suspension lift or does it have a body lift on it? If it has a couple inches of body lift you will likely have significantly more clearance to lift the engine.
David is a Ford Guy now??? Bluwolf Off Topic 16 06-16-2013 08:54 PM
Ford Motor Company Posts Doc Holliday Off Topic 32 04-11-2013 02:24 AM
Ford SD 7.3 Diesel Mileage. Doc Holliday Automotive Repairs 68 10-04-2012 10:08 AM
1998 Ford Ranger Electrical Problem - Turn Signals, 4Wheel Drive Yotta Automotive Repairs 2 04-06-2011 06:59 PM
Subpanel next to Main panel wired the same in 1990 Uncle Wayne Electrical 3 01-20-2011 12:43 AM
