1990 Celica Back-Up Light Switch - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-02-2008, 05:03 PM   #1
Tired, Cold, and Damp
slickshift's Avatar
On my 80's Corolla it was on the tranny
Does anyone know if on the '90 Celica (ST, 4AFE engine, autotranny) is the same way, or if it's on the shifter
I'm having trouble finding it if it's on the tranny
Thanks in advance
slickshift is offline   Reply With Quote
Old 06-03-2008, 04:26 AM   #2
Oldguy
Rehabber's Avatar
If I remember right, it's part of the neutral safety switch. Take it apart and clean out all the old grease (especially in the little springs) and use some silicone dielectric grease to relube it reassamble and install,
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 06-03-2008, 05:33 AM   #3
slickshift's Avatar
Thanks!
You don't remember if it's on the tranny or shifter do you?
Old 06-06-2008, 04:42 PM   #4
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Auto tranny should be the near-bulletproof Aisan-Werner 4. The NSS is on the passenger side on the opposite side of the trunion shaft. There's a couple of little screws holding it on, and the nut in the middle where you'd think is holding it on is merely for prying the switch off (carefully). Disconnect the wire harness and go disassemble the housing. Watch out for small flying parts - they are spring-loaded, hard to find, and non-magnetic copper. Make sure you get it lined up properly when you put it back on or it won't work. Mine still doesn't work, but at least I tried.
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 06-10-2008, 07:36 PM   #5
slickshift's Avatar
Thanks for the very specific directions!
can a power surge flip a light switch? bluebee1314 Electrical 9 07-13-2009 02:33 AM
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 03:06 PM
Adding one recessed light to exsisting switch... JayBird Electrical 1 04-03-2008 07:32 PM
4-way switch and light fixture rtyui2 Electrical 3 12-23-2007 09:48 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
