1970 Honda Cb 450 Idle Problems - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-24-2010, 07:02 PM   #16
1970 Honda cb 450 idle problems
Aah yes in infamous honda twins that wont return to idle speed. early high mileage cb 's had this problem and when I was a mechanic it took me some time to figure out the problem. Everyone including me went straight to the carbs to fix it. The problem is that it's not the carbs creating the high idle.....it 's the mechanical ignition advancer unit located under the points plate, the 2 small springs on the centrifugal unit are sacked and continue to hold the ignition timing at full advance, resulting in high idle even though the idle screws return to closed position. As a quick fix I used to trim 1 end of the spring and fold over the next coil to effectively shorten the spring, better yet get new springs. Remember to mark the points plate before removal or be prepared to go through the whole ******* honda timing procedure again.......Vinny
Originally Posted by cowboykp View Post
I have a 1970 Honda 450. While at idle if I hit the throttle, the engine revs up to about 3000 rpm. and stays there until I turn the Ignition off. Any ideas why? Thanks
vinny123 is offline   Reply With Quote
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 09:44 PM
Multiple problems in 3 year old house I just purchased swenard Plumbing 12 08-31-2009 04:53 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 03:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
