1962 Pontiac - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-24-2007, 11:20 AM   #1
Angry
1962 Pontiac
Hi. We have run across a problem with our "62" Pontiac. It has been in storage for about 10 years. We have changed the gas, rebuilt the carb, new fuel filter and line, new plugs and wires. It is running still very rough. All the above has helped alot as before the wires were replaced I thought the engine was going to shoot out of the car from bouncing. But the only thing I can think of that we did not do is the points. Would that be a possibility for it to be running so rough? Also my husband changed the oil and drained it completely before adding new oil. He put in 5 quarts but when you check the oil it shows overfilled? How could that be? Any ideas would help so much. Sue
suedyer is offline   Reply With Quote
Old 10-24-2007, 12:14 PM   #2
(the original)
Rewards Points: 756
Now that brings back some memories.....many years ago I had a '62 Grand Prix, silver-gray, red leather buckets, 389 tri power, factory wheels....Ahhh, the good old days.....
Yes, it could be points. Also replace the condensor and distributor cap.
The oil level concerns me. Did he replace the filter? If not that would account for extra oil, since it would still have probably 1/2 a quart in the old one. A more likely guess, though, is a sludge build up in the oil pan from sitting for so long. If that's the case, you'll need to do an engine flush and change the oil again.
I'd also run a good cleaner through the fuel system. Sea Foam is the best, IMO. Good luck!
ratherbefishin' is offline   Reply With Quote
Old 10-24-2007, 12:49 PM   #3
I just showed my husband your response, he says thanks. He thought about the sludge but that was as far as it went. He just told me that must be why the oil looks dirty even though it has left the drive way. He;ll try the points, condenser and dist. cap. Thanks.
Old 10-25-2007, 05:27 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Intake/carb/manifold gaskets could have dried up allowing a vac. leak
Check those out as much as possible
Check the timing, and looseness of the chain
Also make sure the wires are routed correctly
slickshift is offline   Reply With Quote
Old 10-26-2007, 08:00 AM   #5
47_47's Avatar
Rewards Points: 62
The points, condenser and cap should be replaced as ratherbefishin' suggested, along with changing of the oil. I would then set the dwell, timing and carb. in that order. I would drive the car and see if this helps the problem. You may have other issues from sitting for 10 years. If the engine still runs rough, you will have to check the engine for mechanical probems with a compression and vacuum gauge.
47_47 is offline   Reply With Quote
97 pontiac instrument panel access sluggermike Automotive Repairs 5 09-19-2007 12:10 AM
