12 Volt 3-Way Panel Mount Switch? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-07-2010, 04:42 PM   #1
Electrician
Proby's Avatar
Radio Shack should have it. You need a Single Pole/Double Throw switch, SPDT
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-07-2010, 07:39 PM   #2
Electrician
Proby's Avatar
Originally Posted by OnThePike View Post
Thanks Proby.
So how does this work, exactly? The center position on the SPDT is the "common"?
Pretty much. I attached a diagram of a 3-way or SPDT switch.
Old 08-07-2010, 07:43 PM   #3
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
i think the SPDT is the same ON/OFF/ON switch you are already familiar with. I have never heard of using 2 of these as 3 ways, but i'm not saying it won't work, just not sure
I have seen 3-way, 12v switches sold for RV's, but they are large, not like a small dashmount job
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-07-2010, 07:44 PM   #4
Electrician
Proby's Avatar
A SPDT switch only has (2) positions.
If you go to Radio Shack's website and search for: SPDT you'll find a bunch of them. Try searching for: 275-648 That's a nice one that will work for you.
What are you going to be doing with this switch? How much current?
Old 08-07-2010, 07:57 PM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
man, it's been a long day..... this should work fine. I'd make sure to use a fuse on the power feed going to the first switch
Old 08-07-2010, 07:58 PM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Yes, I have seen them. If I was going that route, I'd just use whatever Levitton I have laying around.
switches rated for 120ac won't handle the direct current well. they are prone to arcing and other problems under direct current. so it/s probably a good thing that you don't want that look
Old 08-07-2010, 08:08 PM   #7
Electrician
Proby's Avatar
I know exactly what you mean about Radio Shack, I use Parts Express instead.
Good luck with your project.
Old 08-07-2010, 09:19 PM   #8
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I wasn't aware that a SPDT switch could be used as a 3-way switch. .
what you do is use the first switch as a standard switch (1 line/ 2 load terminals) but on the second switch, you use it backwards (2 line terminals/ 1 load terminal).
simply put; you feed hot to the "C" terminal on one switch and feed from the "C" terminal on the other switch to the load (light). Then you simply connect each of the unused terminals on each switch to an unused terminal on the other switch. Those are your travelers.
viola`, you have a low voltage DC 3 way.
I would suggest you power the first switch with a switched hot that would be hot in either "run" or "acc" on the keyswitch.
Old 08-11-2010, 07:03 PM   #9
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Does anyone use spade bits on dash plastic?
i think just about everybody does
Old 08-11-2010, 07:58 PM   #10
Electrician
Proby's Avatar
I'd drill it front thru the rear. I don't think you'll have any issue.
Old 08-12-2010, 11:08 PM   #11
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I'm concerned with a clean hole. There's only 2mm circumference of switch edge (ridge border). That means I only have 1mm to play with. Spade bits tend to drag material and rip edges on plastic.
You can always drill an undersized hole, and use a Dremel with the little drumsander bits to open it up a little at a time untill you get a good fit
3-way switch help amit Electrical 17 02-15-2010 04:17 PM
What switch to install between panel and 220 volt heater Rogers Guitar Electrical 4 01-21-2009 07:08 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Moving several circuits to sub panel WoodworkerDave Electrical 2 09-27-2008 03:05 PM
