Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-04-2011, 07:22 PM   #1
07 Outback Hood Latch Opens Partially
My 2007 Subaru Outback's hood has started popping up now and then
as I drive down the road. The hood does not open. It just goes to the
first release and shakes until I stop and re-close it. It's been happening
more and more as time goes on.
I have lubricated the mechanism and the linkage, but this did not help.
Has anyone here experienced this before? What should I look at now
as the possible cause? Or does this require a technician?
Jazan is offline   Reply With Quote
Old 11-04-2011, 09:29 PM   #2
Make sure the release cable is returning all the way. If it is the latch is most likely shot. If not releasing you need a new cable they get old and bind inside the outer sheathing.
cjm94 is offline   Reply With Quote
Old 11-05-2011, 01:34 AM   #3
As a master Subaru tech of 20 years, try to adjust the latch first!! It's not up high enough.. It's only 3 12 mm bolts and slide it up.. Is the car from the east coast??
Rust can cause this latch problem also.. Has the car been wrecked?
Mack daddy is offline   Reply With Quote
Old 11-05-2011, 07:31 PM   #4
Thanks you both for your helpful replies. The cable is in good shape and moves freely. No rust or dirt in or around the latch mechanism. When I
decided to try the adjustment by loosening the three screws, the upper
two are reachable, but the lower one is blocked. Is there a special tool for that one? Or is does the grille have to come off before I can loosen it?
Also, once I get the screws loose, are the screw holes slightly slotted
to allow for adjustment upward as you suggest? Thanks again!
Old 11-05-2011, 08:24 PM   #5
You can get a swivel socket on it.. It does. It have to be loosened much.. That should take care of your problem...
Tags
hoodlatch, subaru outback
Hood Latch Broken sweaty Automotive Repairs 2 09-25-2011 11:10 AM
Latch on Sliding Door Budfudder Windows and Doors 2 09-11-2011 04:01 AM
range hood opening is bigger than range hood jacks16 HVAC 2 06-23-2011 07:19 AM
Hood / Vent Requirements for Gas Stove WaldenL HVAC 1 09-09-2009 04:38 PM
Subaru hood latch release ?? andyslater Automotive Repairs 6 08-05-2009 12:06 PM
